which 2 transistor cable to use?
Car: 89' Iroc
which cable would work best on my 89 350 TPI? I am going to be running moates software on my laptop to scan with.
Car: 87 T/A
Engine: 441 SBC 12.5:1 0.680" Lift
Axle/Gears: 4.10 TruTrac Moser 9"
The first one. If you look, you'll see it's bidirectional as it needs to be for 8192...
Car: 89' Iroc
can all of the grounds be hooked to the ground that goes to the 9 pin connector? look at my picture and see if you understand my question.
Originally posted by caleb
also, do i need to hook the data cable to pin E instead of pin F
You will use pin M or E for serial data. Your connector should be 12 pins, not the 10 pin in the picture.
Car: 89' Iroc
okay this may be a dumb question, but all the little things i circled in red on my previous post, are grounds correct? and what is the 1N4148 thing?
Car: 85 Corvette
Engine: 355 Superram
Transmission: 700R4 Transgo Shift Kit
You have a thin red circle around the line from pin 3. This is not a connecting point. The circuit connects at dots on the diagram. If two lines cross and there isn't a dot, they don't connect.
Car: 89' Iroc
Car: 89' Iroc
well went to the new radio shack, and they had everything I needed, and the guy didnt even give me the you have questions we have blank stares! get this, the guy even drives an 86 Iroc that he just dropped a worked 350 into! talk about luck of the draw:hail:
Car: 89' Iroc
ok, finished the cable hook it up and nothing, ya thats right nothing, I think that the MPS2222A package is labeled wrong, i have a ttached a drwing of what is on the back of the package versus what is on the diagram, is this my problem? I hooked the transistors up accodring to the package and not the diagram
Car: 85 Corvette
The drawing on the transistor package views the pins from the bottom. I had trouble with my 1 transistor cable on one computer but it worked on two other computers.
Car: 89' Iroc
I need some help Craig!
hey, just wondering if anyone knows, which way the transistor is supposed to go in? and on my diode one end has red tape on it, and one end has white tape on it, which end goes to ground? somebody please help, i am going to try and redo my cable again tonight!
Car: 87 T/A
Go to Yahoo and do a quick search on 'npn transistor' and 'diode direction'. You'll want to understand what the deal is. There are a couple of very nice & brief summaries out there that will give you good background...
Car: 87 T/A
E or M, take a look and see what hole is full of metal.
I know many people have said it works. Haven't tried myself though..
craig, is this cable confirmed to work with your software? which pins do i need to hook into on the aldl side for data? E?
Car: 89' Iroc
hey morley
hey, i finally got it to work, dont ask me but i had to put a 10k resistor betrween pins a&b is this normal? it makes the car run like $hit! Any way when it wnet into graigs software, only some of the variables would display, is the because of a bad connection? I am running a Toshiba 730xcdt laptop P100 2gb HD 16mb RAM. I was thinking would it give me a better connection, if i pull down the aldl connector, and splice into the back of that, then i can just roll out the cable when needed, and just pop in that 10k resistor, and im set! If i am full of crap let me know:lala:
Make sure you have a 10k resistor in there (yes you need the 10k), might want to try another one to be sure.
Also use 110v power for the laptop and try it again, a weak battery or trying to tap into the laptop for the 12 volts for the cable will cause partial data streams. Use the vehicle for the 12 volts for the cable.
your laptop will work just fine for the scanner, I am using a Tecra 500CDT (120 mhz processor) and it works great.
Car: 89' Iroc
ok, where would i hook up the power from the car too? would i splice that into my cable? or do i just need to hook that up to the ALDL? i have attached a picture, I have circled two spots on the cable, where should i hook the 12v into?
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
AHA! Been trying to get the moates proggy working for MONTHS!
Made like 3 cables. and now I see, I think i've been putting the transistors in backwards.
I'd run the moates softare, and turn the car on. it would print
Last byte recieved: 0F or FF, or C0
But would never link!
-- Joe
-- Joe
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
OKie. That was the problem. Anyone whos having problems with a moates cable should be linked to this post, Tim.
Flipping the transistors around seems to be an obvious mistake, but I never thought about it until I saw this post and. whalla! I did it wrong.
-- Joe
-- Joe
Z28/ZR1
Oct 23, 2015 01:04 PM
TMZIrocZ350
Oct 7, 2015 12:09 PM
rs_z28_vert
Sep 30, 2015 09:47 PM
