Easy quickie
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
Easy quickie
When you put a programmed prom back into the ecu does the ecu need to go through a period of "re-learning" like it does if you disconnect the battery?
Curious if I should pay attention to the blm's that i should be getting later on today.
I open the ECM power circuit (1-pin Weatherpak near the battery positive terminal) when swapping PROMs, so when I turn the key w/ a new chip I'm seeing BLMs related directly to the software I'm running. In this case, the BLMs I see are definitely noteworthy.
It's possible to swap PROMs with the ECM powered, but then you'd have BLMs from the old software being applied (initially) to the new software's config.
Gunner242
Dec 25, 2015 04:49 PM
3.8TransAM
Oct 1, 2015 07:47 PM
