Any advantage to adding a passanger side o2?
Old Oct 12, 2002 | 06:24 PM
PLANT PROTECTION's Avatar
Car: 1987 Monte Carlo SS
Transmission: 200-4R
Axle/Gears: 7.625 10 bolt/3.73s
If I were to add a o2 sensor on my passanger side collector, would I be able to achieve a better tune by monitoring both sides of the motor? Would a toggle switch work to switch back and forth between the two? Other advantages I can think of is making sure both driver and passanger injectors are working and help pinpoint where a vacuum leak is. What do you think?
Old Oct 15, 2002 | 07:13 AM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
The ECM has no provisions to monitor both. It wouldn't really benefit you with your current setup.
The toggle switch idea may infact, help somethings. but.. I dunno if itd be worth it.
Bubbajones_ya
Aug 31, 2015 12:02 PM
corlando52
Interior Parts Wanted
Aug 24, 2015 11:32 AM
Cameeeero
Aug 20, 2015 03:06 AM
mizz0313
Aug 12, 2015 06:45 AM
wruiz
Aug 11, 2015 02:59 PM
