What does all this sensor data mean?
Old Oct 16, 2002 | 09:18 PM
MrNova's Avatar
I did some quick runs to log some data, just a cruise around the block. Now I've got this pile of data and I don't know what anythimg means. Where can I find out? Using WinALDL
Old Oct 17, 2002 | 05:24 PM
MrNova's Avatar
Anyone? Can someone at least tell me what some of the acronyms like mean?
Maybe If I touch some data people can help. I don't quite understand, but I think im running either lean or rich, not sure.
Old Oct 17, 2002 | 05:58 PM
MrNova's Avatar
Here is the data in excel format from winaldl
File Type: txt
Old Oct 17, 2002 | 06:05 PM
Ed Maher's Avatar
Car: 04 GTO
Transmission: M12 T56
There are way too many things to just go through. Do searches on 'em and you'll find anything you could need to know. But trying to use notepad is insane, use a spreadsheet program and you can graph things and sort things, etc
Old Oct 17, 2002 | 07:31 PM
Chop_Top's Avatar
Were you really doing 90MPH ? shame on you before the car is even warmed up!
Old Oct 17, 2002 | 07:37 PM
MrNova's Avatar
Um, no, i was doing 56mph. If you look at the raw:mph problem it says 56mph. For some reason 56mph becomes 90 "speed" under the sensor column, go figure
Old Oct 17, 2002 | 07:40 PM
MrNova's Avatar
I use excel XP, I just posted in notepad because it wont let you attach excel files
Wow, my BLM values look VERY messed up, they fluctuate at regular intervals from 0-256
Old Oct 17, 2002 | 08:33 PM
JPrevost's Avatar
Car: 91 Red Sled
Your BLMs are between 125 and 131 bust mostly at 129-130.
What do you have a question on because nothing is really all that confusing. BLMs and INTs tell you what the ecm is doing with the fuel tables from input from the o2 sensor. BLMs above 128 means the ecm is adding fuel, less than 128 and it's taking away from the tables. INT is the same thing only more fine tuning (worthless with TBI). Everything else is what it says it is.
IAT is the intake air temp, CTS is coolant temp, MAP is vacuum, volts is volts, etc.
Old Oct 17, 2002 | 08:36 PM
MrNova's Avatar
Im kind of confused, because yeah your right, my BLM's do seem normal under RAW. But under Sensor they are totally wacky, which do I "trust"?
Old Oct 17, 2002 | 08:56 PM
Chop_Top's Avatar
Sorry I was just confused by the 93% tps,4300RPM and the 187MAF... It could happen to anybody
Old Oct 17, 2002 | 08:58 PM
MrNova's Avatar
Yeah, I wish there was a help guide somewhere as to what all these values mean. Searching the forums is pretty hard :/
meeklay812
Oct 1, 2015 03:46 PM
dusterbd
Sep 29, 2015 08:40 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
tattmann
Sep 27, 2015 05:20 PM
efiguy
Sep 27, 2015 01:30 PM
