sy ty ecm piggyback on a 730?
Old Oct 31, 2002 | 12:15 AM
drive it's Avatar
What I'm thinking (yea I know that can be kinda scary!), is piggybacking a sy ty ecm onto a 730 ecm. That way the 730 can still controll all smog functions; air divert valves etc. and then have the sy ty for ve tables of 2 bar map.
I know that the dfi has been PB'ed, but I'm not famaliar with the sy ty ecm. Seems like it should be doable....
Any help apprectiated!
Old Oct 31, 2002 | 11:11 AM
drive it's Avatar
Any body???? Also refresh my memory...is the sy ty ecm batch or seqential? If not batch then there would be a bit more rewiring..
Old Oct 31, 2002 | 08:39 PM
SATURN5's Avatar
Car: 84 SVO
Engine: Volvo headed 2.3T
Transmission: WCT5
Axle/Gears: 8.8" 3.73
The 749 is batch fire. As far as running "dual" ECMs, that won't work. Several reasons, including, the sharing of inputs, and how do you plan on switching back and forth between ECMs without having any glitches. ie , setting codes, misfires, etc? Best bet is to use the 749 solo, or look into using the 730 (repinned to run as a 749) with the syty code. Both have been done. I haven't tried the 749 inna 730 before, but it has been done sucessfully. HTH, Bob
InfernalVortex
Apr 20, 2021 11:31 AM
Falcon50
Aug 22, 2020 03:26 PM
thunder57
Nov 7, 2015 02:28 PM
Jlanz55
Sep 29, 2015 08:55 AM
efiguy
Sep 27, 2015 01:30 PM
