how to test max232 to see if correct
Old Nov 10, 2002 | 09:18 PM
caleb's Avatar
Car: 89' Iroc
I have loaned a max232 converter from a prominant member of this board (dont want to mention his name, because I dont know if thats okay with him) when he sent it, he included a male and female db25 end so i built the end according to the AKM site. According to the AKM site i should be able to connect to hyperterminal, and have it echo anything i type, but when I connect to hyperterminal all it does is let me type. Also when the cable and converter are connected to my car using craigs program, it just says last byte from com port 0 and it wont link up, any ideas are appreciated.
Old Nov 12, 2002 | 11:57 PM
Bluevette85's Avatar
Car: 85 Corvette
Engine: 355 Superram
Transmission: 700R4 Transgo Shift Kit
Are you using a 10K ohm resistor between pins A+B of the ALDL connector?
Old Nov 13, 2002 | 08:42 AM
caleb's Avatar
Car: 89' Iroc
okay, i got it figured out, i was trying to pull the serial data from the wrong pin! i just happened to be looking through my chilton manua, and it showed that there were two different pins that could be used for serial data, and so i tried the other one, pin M i believe and it works like a charm now
Old Nov 14, 2002 | 09:02 AM
greg_pl's Avatar
Car: IROC 5,0 TPI '88
Transmission: auto
Hi Caleb!
I pick this topic for 3 years ...
look too on
http://www.ttspowersystems.com/
and use this software ALDL_TEST to test :
http://www.ttspowersystems.com/freedload.htm
and look on :
http://www.ttspowersystems.com/dm_dload.htm
it is very nice software for MAX232 interface !!!!!
I sell sometimes my max232 interface on ebay
Old Nov 14, 2002 | 11:57 AM
caleb's Avatar
Car: 89' Iroc
thanks for the links, I will try them out tonight
Hotrodboba400
Dec 10, 2019 07:07 PM
Whata69
Mar 2, 2016 06:34 AM
New2Chevy
Sep 28, 2015 12:35 AM
Glowsock
Sep 6, 2015 06:40 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
