BLM's stuck at 160!!!
Old Nov 12, 2002 | 08:15 AM
justme's Avatar
I recorded some data from my car today after the 730 swap. BLM's stayed at 160 in all 46 frames. RPM range 600-1400 (car wouldn't idle) INT were between 129 and 156, MAP was between 57 and 78. The only thing I modified in Tunercat (AUJP bin)was the injector constant and cylinder volume. Any suggestions?
Old Nov 12, 2002 | 10:07 AM
Morley's Avatar
Where did you set the injector constant? Sounds like you set it too high.
Old Nov 12, 2002 | 11:20 AM
justme's Avatar
I set injector constant to 26 Lb. I believe that is what injectors are in it. They are light blue top Ford injectors.
Old Nov 12, 2002 | 11:30 AM
kevinc's Avatar
Car: 1982 Z28
25.2# was the setting mine liked w/ the blue SVOs and pressure set to 46psi.
Lowering your injector constant will cause the ECM to pulse the injectors longer, increasing net delivery and pushing your BLMs down. Whip out your chip burner and start burning.
Old Nov 12, 2002 | 01:28 PM
justme's Avatar
46 PSI. At idle with vacuum hose off?
Old Nov 12, 2002 | 09:27 PM
kevinc's Avatar
Car: 1982 Z28
46psi at idle w/ the vac hose off.
Old Nov 13, 2002 | 02:24 AM
Morley's Avatar
Try setting the injector constant to 23-24 and see what effect that has on BLM's.
Old Nov 19, 2002 | 10:52 PM
justme's Avatar
Set Inj. Constant down to 24 and it is idling better but shouldn't I be messing with the VE tables to fix this instead of the Inj. Constant (just seems like a band-aid to me) or is it typical to have a different Inj. Constant setting different from actual size? Also, when you first start a cold motor in open loop what parameters does the ecm use to get a base pulse width for Inj? What can (and should) I change to play with my cold start open loop A/F?
Old Nov 19, 2002 | 11:10 PM
justme's Avatar
Found the answer to my second question in Tunercat there is "Open Loop %Change Fuel/Air Ratio at Idle" it is set at 0 now so if it changed to say 5% will that make the A/F ratio 5% higher to 15.46 leaning it out more or am I Bass Ackwards?
Old Nov 20, 2002 | 11:06 AM
RBMZ28's Avatar
Car: 87 IROC (low 12's)
Engine: 400 sbc .040 over
Transmission: 700r mod
Try what Traxion says, it should work. But if not, read and read well Funstick's sticky on 32&32b tuning.Help me out a whole lot!!
Old Nov 20, 2002 | 11:32 AM
justme's Avatar
Isn't that post about MAF? I'm running SD. With all the data you have the option to change in TC, I am afraid to mess with anything too much for fear that if I change the wrong thing now then down the road I find out I should have messed with something else first.
Mark_ZZ3
May 24, 2018 01:02 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
88SS6SPEED
Nov 11, 2015 07:05 AM
tmellott89
Oct 14, 2015 02:06 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
