Winaldl not working
Old Dec 4, 2002 | 02:33 PM
mylittlemule's Avatar
Car: 87 Wrangler
Engine: 355 TBI
Winaldl not working
I built the cable, installed the software, and i get nothing. Will the check light come on while installed into the interface? I'm going back to check the cable. the other com ports say error so i'm sticking with the one that says okay. Is thier a length limit on the cable? any advice?
Old Dec 4, 2002 | 05:18 PM
funstick's Avatar
did you use a ressitor across pin a & b
Old Dec 4, 2002 | 10:57 PM
Car: 87 Wrangler
Engine: 355 TBI
i did use the resistor but the light didn't come on. SShould it?
Old Dec 5, 2002 | 02:21 AM
Morley's Avatar
No.
Old Dec 5, 2002 | 05:15 AM
JPrevost's Avatar
Car: 91 Red Sled
Don't make the cable too long. Under 10' and you shouldn't have a problem. When you built the circuit, did you build the circuit at the serial port of the computer or at the other end of the cable?
What car or if you know, what ecm are you using.
Double check that the com port is working with some other hardware you might have. A TI graph link for their calculators always helps me diagnose com port issues.
Old Dec 5, 2002 | 03:27 PM
Car: 87 Wrangler
Engine: 355 TBI
Well my first mistake was the cable length. Its about 15 ft. The circuit is at the serial port. But, I'm not sure what i can use to test the port. What is a TI graph?
Terrell351
Jun 13, 2021 01:13 PM
Jake_92RS
Jan 28, 2020 10:37 PM
Vintageracer
Jan 10, 2020 05:33 PM
Jk_Under
Aug 17, 2015 03:08 PM
Fronzizzle
Aug 17, 2015 02:52 PM
