Have my 87 GTA bin file, but need...
Old Dec 7, 2002 | 02:12 PM
borgx's Avatar
Car: 1987 Pontiac Trans Am GTA
Transmission: WorldClass T5
Axle/Gears: 3.70
Hi all!
Great reading I've been doing in this section! Thanks for all that have contributed!
Now... I removed the stock chip from my 7165 ECM from my 1987 GTA with 305 TPI engine. I have read the chip to get the stock ABUS bin file...
After reading all kinds of stuff, I have dicovered that many of the tables were set to crap specs by GM. My question: Does anyone have a "corrected" bin file for an 87 305 TPI that I can use as a base instead of starting with my stock bin file?
The car has a Crane 2032HR cam, 1.6 Roller Rockers, SLP cold air, 22# injectors, headers, 3 in cat back, SLP runners, ported plenum, etc.... I know it is doubtful that anyone would have the "perfect" bin for this setup, but I'm hoping to get a closer start than stock!
Thanks to anyone that can assist!
Old Dec 12, 2002 | 12:33 AM
borgx's Avatar
Axle/Gears: 3.70
Hmmm... ok. Anyone got a HyperTech bin file or something better than stock to start with at least?
Old Dec 12, 2002 | 06:29 AM
TRAXION's Avatar
Car: 2005 Subaru STI
Engine: 153ci of Turbo Power!
Transmission: 6-Speed
- There's no such thing as a generic 'corrected' BIN file.
- Hypertech is no better than stock
Once you understand the above two statements then you will be well on your way to learning how to program PROMs. The latest GM code is the best place to start. On the MAF cars that I have helped to tune I started with the $6E ARAP file (which is also a cold start injector delete - just unplug the injector for now). The timing might be a little bit aggressive for your setup but that's easy enough to fix.
Tim
Old Dec 12, 2002 | 10:38 AM
SmokinZ28's Avatar
James, I have a chip with the 89 ARAP bin that champo did for me that you can look at. Wanna help with mine when you get yours done? BTW did you ever figure out my laptop? hit me on MOFBA.net
TX-SleeperC5
Feb 24, 2016 01:34 PM
ramicio
Sep 28, 2015 01:18 PM
Linson
Sep 21, 2015 01:08 PM
okfoz
Sep 15, 2015 05:22 PM
pacoelrapido
Sep 11, 2015 02:41 PM
