ford injectors now pinging????
Old Dec 12, 2002 | 06:58 PM
mystikkal_69's Avatar
Car: 1988 IROC-Z
Engine: L98 (350 TPI)
Transmission: MD8 (700 R4) + 3.42 LS1 Rear
i installed 8 21# ford injectors in my 88'. i am running an 89' AUJL stock bin. the problem i am having that i am getting slight pinging when i got WOT. i have no access to a scan tool so i can only assume that the car is running lean maybe??? what do u guys think? according to the calculations it should be running just fine?
my original 88' AYBA bin was set for 23# injectors?
ford 21# @ 39.1(2.7bar)= 22.78# @43.5 psi
GM 22# @ 43.5(3.0bar) = 22# @ 43.5 psi
350 TPI A4
Old Dec 12, 2002 | 10:24 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
Re: ford injectors now pinging????
You have to change that.
Other wise you'll have no clue as to what to do, unless you want to devote all your time to learning plug reading. And you can spend years just doing that.
tuning, by what do you guys think, just gets lots of maybes backed up with I thinksos. Hardly the way to tune an engine.
Old Dec 12, 2002 | 10:49 PM
Car: 1988 IROC-Z
Re: Re: ford injectors now pinging????
i was afraid of that. looks like i'll have to get one or make one if at all possible. thanks alot i'll have to look at craig's software.
Old Dec 14, 2002 | 12:39 AM
DannyT's Avatar
Car: 89 Iroc
Engine: 383
Axle/Gears: 3.45
What is your base timing set at? Is it the same as before you swapped the new injectors in?
Old Dec 14, 2002 | 10:49 AM
Car: 1988 IROC-Z
yup it's still @ 6 BTDC i double checked it to make sure it's didn't move or something. i band aided the problem. i am "simulating" 23# injectors. by running my injector constant @ 22.06# (read above for more details on ford injectors and ratings). the car has gained some more power so says the butt dyno and the the two black tires marks @ 35 2-1 down shift. the pinging is almost non-existant. woo hoo i'll get some 24# injectors when i get some more money. that will have to do for now........ w/o a scan tool
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
Veaceonee
Sep 29, 2016 08:15 PM
92-Formula
Dec 12, 2015 10:34 PM
webeeZ28
Sep 14, 2015 12:00 PM
