Computer controlled carbs
Old Jan 3, 2003 | 12:53 PM
laiky's Avatar
I have the intro article in my hands, it says its for fuel injection. Can someone tell me if this info applies to LG4 computer controlled carb cars? If not what is different. Please be patient i am completely new to prom burning!
Old Jan 3, 2003 | 06:25 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
Re: Computer controlled carbs
A prom is a prom, more or less.
Trouble is there are no documents explaining the locations for a CCC ecm. The best CCC prom that I know of is in the ZZZ retrofit kit. In the instruction sheet it gives the part no..
With that prom, then you'll just need to rework the secondaries, try Doug Roes Quadra Jet book for answers on that.
Old Jan 3, 2003 | 07:33 PM
laiky's Avatar
my problem is that right now i'm running my old hypertech chip. it seem sto have way too much advance in it. i need to run more static timing to get the car to idle well, but when i do i get over 42 degrees at full advance. it may be ok at that advance but i'm reluctant to run it like that. Everything i read says 34-38 degrees total advance. I have a lot invested in my motor and i am afraid to run soo much timing. The other reason was that i would lik to be able to improve idle quality and maybe fuel mileage. i know if i advance the timing i may improve both but like i said i'm afraid to go past 38 degrees. My car is an 84 with the LG4 computer with NO knock sensor. I understand i can upgrade to the 87 with a knock sensor but i do not know what wiring changes are neccessary for that to work.
Old Jan 4, 2003 | 07:16 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
The problem is the Hyperhick prom.
Yes, you'd have to add the K/S module, and some wiring, maybe a look at a shop manual would answer your guestions about what exactly you have to add.
Like I said get the instruction sheet for the ZZZ retrofit.
eightsixseven
Dec 16, 2024 01:50 PM
midge54
Jan 29, 2017 07:00 PM
ChaseDale3and8
Sep 1, 2015 01:49 PM
theurge
Aug 21, 2015 12:46 PM
Dialed_In
Aug 20, 2015 01:45 PM
