scan tool won't connect
Old Jan 9, 2003 | 07:59 PM
91bluemetalicRS's Avatar
I am about to order everything I need to start burning my own proms, my question is I can't get any scan tool to read what my car is doing since my swap. went from 305tbi to 350 tpi, the car is a 91 rs. Can anyone lead me in the right direction?
Old Jan 10, 2003 | 12:11 AM
funstick's Avatar
check to make sure your pinout for the aldl link is correct you may also have to check thre aldl connector itself gm moved the data pin a few times over the years.
Old Jan 10, 2003 | 08:24 AM
does anyone know which pin is the data link coming out of the ecm to the aldl. I figure I will need to bypass or switch it around. The computer is from a 91 sd l98. Checked in the Helms manuall last night but couldn't find anything. Thanks for your help in advance.
Old Jan 10, 2003 | 09:07 AM
HighHopes85's Avatar
It's in the electrical part that shows pinning for all the pins in the ECM.
ftp://ftp.diy-efi.org/pub/gmecm/manu...730v8tpi-1.jpg
If you are using Diacom, it will read pin M, so repin accordingly.
Old Jan 10, 2003 | 09:13 AM
funstick's Avatar
the ornage wire going to the ALDL connector iself should be on pin M for that ecm.
you should also check to make sure its on the corretc pins at the ecm.
Old Jan 10, 2003 | 10:59 AM
hehe. I looked at that diagram last night, I missed that 461-org wire. I will fix it up tomorrow. Thanks alot I knew you guys could help!
Old Jan 10, 2003 | 11:00 AM
hehe. I looked at that diagram last night, I missed that 461-org wire. I will fix it up tomorrow. Thanks alot I knew you guys could help! double post
Old Jan 11, 2003 | 11:13 AM
ok the data link is hooked up to E. On the M **** I have a light brown wire? I disconnected it and it hooked up the orange wire and walla it works now. Any problems with unhooking the brown wire? THanks again for the help
Old Jan 11, 2003 | 11:55 AM
funstick's Avatar
i think the brown wire on the aldl for the 165 is for TCC indicator. thats about it i guess itll be ok. as long as it talks man its all good/
Hotrodboba400
Dec 10, 2019 07:07 PM
Fronzizzle
Sep 8, 2015 12:10 PM
muttracing
Brakes
Sep 6, 2015 08:12 PM
mrdevontay
Sep 2, 2015 08:04 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
