Whick year/make/model of 3 wire heated o2 to get?
Old Jan 11, 2003 | 09:56 PM
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
What heated o2 sensor do I need to get correct readings for tuning with a scanner? Would a 3 wire heated o2 from a fullsize '95 chevy truck with a 4.3 liter V6 work? If so, I have a new Delco heated o2 from my truck listed above. If not, I will get the best one that you guys recommend. With my single wire o2 now located in the y-pipe, car isn't going into closed loop for me to get readings to tune by.
Thanks,
Mike (1bad91Z)
Old Jan 12, 2003 | 01:20 AM
V8Astro Captain's Avatar
Car: Bee-Bowdy
Engine: blowd tree-fity
Transmission: sebin hunnerd
Axle/Gears: fo-tins
'92 Astro van vin code "Z"
Old Jan 14, 2003 | 10:55 PM
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
Ok, on a 3 wire '92 Astro van Z code heated o2, there is one black wire and two white ones. Which one is ground, power, and ECM signal wire? A picture would be GREAT if possible!
Thanks again,
Mike (1bad91Z)
Old Jan 15, 2003 | 07:40 PM
CRAZ28's Avatar
I just installed a 3 wire o2 in my TPI Gmc truck, it works great! The black wire is the computer signal wire, the other two white wires are for the heater, one + one -, it doesn't matter which one is which.
Old Jan 16, 2003 | 07:13 PM
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
It doen't matter what white wire is power or ground? That doesn't make sense?
Craz28 - did you use the 92 AStro van o2?
Old Jan 16, 2003 | 08:06 PM
TRAXION's Avatar
Car: 2005 Subaru STI
Engine: 153ci of Turbo Power!
Transmission: 6-Speed
That is correct. It does NOT matter which wire is power or ground. The white wires go to power and ground (doesn't matter) and the black to the signal.
Tim
Old Jan 17, 2003 | 06:29 AM
CRAZ28's Avatar
yes, i used one out of a 92 astro, I used a matching connecter from the wiper motor harnness of a 3rd gen firebird and it plugged right in to the O2. works great
Old Jan 19, 2003 | 07:35 AM
87_TA's Avatar
Take a 12 v light and hook it up backwards,it works.
Anything that makes heat is a controlled dead short therefor grounding a power wire so if you reversed continuity it would make no difference its stilll a short.
ndndndnd
Carburetors
17
Sep 5, 2015 06:24 PM
mustangman65_79
Sep 1, 2015 03:51 PM
86IROC112
Aug 21, 2015 07:20 PM
stalkier
Aug 21, 2015 01:54 AM
kyle5647
Aug 15, 2015 11:56 PM
