spark timing table in $6e
Old Jan 24, 2003 | 03:32 PM
Red87GTA's Avatar
I'm working on an ARAP based code for my car. From what I've read LV8 is just the airflow in gps. If that is the case and LV8 doesn't get combined with the TPS voltage in any way then half of the table for the spark map is useless. You can't have 200grams/sec of air flow at 1500 rpm so what ever value is in that spot on the table would be unused anyway. So basicaly what I am asking is if the LV8 is just air flow or if it is a combination of airflow and throttle position.
thanks
Mike
Old Jan 24, 2003 | 04:01 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: spark timing table in $6e
thanks
Mike
LV8 is neither. It is Airflow divided by RPM.
LV8 = AirFlow/RPM
Were did you read that?
RBob.
eightsixseven
Dec 16, 2024 01:50 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Red iroc-z 305
Sep 30, 2015 05:22 PM
Armored91Camaro
Aug 12, 2015 09:41 AM
