Got blm #s need help[
Old Jan 28, 2003 | 06:43 PM
Mike Massey's Avatar
OK guys I have a 89 gta with 383 cid 224/235 520 in 530 exh . with a 115 lobe . My engine idles around 900 rpm tps is .54 blm# 108 in cell 5
in park at 2500rpm tps is .74 blmis 106-108 in cell 11.
The problem im xperiencing is my headers are glowig after a normal cruise and of course xtreme under hood temps. Any advice or help is greatly appreciated. tHA
NKS.
:hail:
Old Jan 28, 2003 | 08:07 PM
Colt's Avatar
Car: '89 Formula
Engine: 383 Megasquirt
Axle/Gears: 7.625
'165' ECM?
What size injectors?
What cylinder heads?
What intake manifold setup?
Are those BLM results with the stock chip?
Quiz: Knowing that your BLM's are below 128, what is the computer doing; adding or removing fuel?
tom
Old Jan 28, 2003 | 09:12 PM
30lbs svo inj.
afr 195 cc heads
miniram2
custom burned ed wright prom
answer to question -- I woild think it is trimming fuel with those numbers
thanks
Old Jan 28, 2003 | 10:33 PM
hectorsn's Avatar
Car: 78 Regal
Engine: 82 FBod LG4 305, 730 ECM
Transmission: M20
Axle/Gears: 4.10
Headers glow because the mixture is still burning on the way out either because the timing is too retarded or way too much unburned fuel. They also glow because of extreme exhaust temperatures mostly caused by vacuum leaks (lean AFR's) at those RPM's.
Old Jan 29, 2003 | 04:58 PM
Colt's Avatar
Car: '89 Formula
Axle/Gears: 7.625
If it's a custom burned Ed Wright prom then I would contact him and tell him what's going on. I believe he will work with people to try to get a good match.
Old Feb 2, 2003 | 07:57 PM
TKD89RS's Avatar
Car: 1995
Engine: 5.7
so if blm's are above 128 then its running lean and is adding fuel. where should they be
Old Feb 14, 2003 | 10:31 AM
91L98Z28's Avatar
Car: Z28
BLM should ideally be 128. at 128, the ecm is not adding nor removing fuel meaning the calibration is correct at that individual point.
Mark_ZZ3
May 24, 2018 01:02 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
antman89iroc
36
Jan 31, 2016 08:42 AM
ULTM8Z
Sep 16, 2015 09:15 AM
CORV3TT3
Aug 23, 2015 11:26 AM
