Anyone with an EPROMER-5 "I NEED HELP "
Ok I just tried to program for the first time and I am having trouble with the AT29C256 chip. When I try to program it gives me Program Failure Address: 0h ,Programming BYTE:10h,Read BYTE:FFh Aborting Programming
Can someone please help me!!!!!!!!!!!!!!
yes it is plugged and there is both a red and green light both on with it plugged in to the power supply
After searching last night a good bit I think I need to stack my bin file to get it to 32k How do I go about this I am not familar with how to do this with DOS/ prompts could you explain this or give me a link that will explain this to me, Thanks
Car: 84 SVO
Engine: Volvo headed 2.3T
Transmission: WCT5
Axle/Gears: 8.8" 3.73
Re: Anyone with an EPROMER-5 "I NEED HELP "
to stack a 16K bin into a 32K bin..
have a copy of the bin on C: drive.
in dos at c: prompt.
copy b/ 16k.bin + 16k.bin 32K.bin
example.
copy b/ malibu16.bin + malibu16.bin malibux2.bin
malibux2.bin will be your combined bin file located on C:
Ok I was putting them in wrong I think, now I cant get it to program, again it gives the same error message as stated before.
It is also telling me when I read the chip that it is all FD's not FF's
how can I erase the chip before programming? I also tried my other chip incase I messed up the first one and get the same thing.
I am so screwed up any ideas???????????????????
Car: 84 SVO
Transmission: WCT5
Originally posted by SATURN5
Bet you have it inserted wrong in the zif. the at29c256 is 28 pin, the zif will take up to 32 pin chips. make sure that you put the chip to the rear of the zif, ei leave the first two rows open (pin1 and pin 2, 17,18. However, as I have done this myself, be aware that the eprom may have fried. place it correctly and see if you fill it with FF's
Car: 1987 Monte Carlo SS
Transmission: 200-4R
Axle/Gears: 7.625 10 bolt/3.73s
I got my chips from Graig Moates where did you get yours from?
Re: Re: Anyone with an EPROMER-5 "I NEED HELP "
example.
example.
copy /b malibu16.bin + malibu16.bin malibux2.bin
John
I get the same error message. My BIN is a 32K so I don't have to stack it. It will erase fine and it reads all FF's however it will not program. I am also using the 29C256's. I have one that wont erase, does this mean its fried? I inserted them wrong, but I had one with a BIN on it and when I fixed it and put it in right it read the BIN fine, erased fine, Blank checked OK but just won't program.
