WOT Spark Advance?
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
WOT Spark Advance?
I'm trying to find out my problem with the superram power. I'm getting 090-750 02's and 0 knock retard anywhere. It was showing 34-35 spark advance while cruising but only 22 degrees at WOT. should it be more or no? Fuel pressure is set at 42 cause i figured it there is no detonation why do i need more fuel? I think I'm wrong on that part but can somebody clear that up? Thanks BTW The chip is a little bit modified 89 350 Auto chip.
