Implementing Cutout position as a variable in the ECM
Old Apr 20, 2003 | 09:38 PM
TonyC's Avatar
Car: A Camaro
Engine: Weak
Transmission: Weaker
I'm considering buying an exhaust cutout for my car and I was thinking that since the engine responds differently to different positions of the cutout, could this be used as a parameter when calculating the fuel needed (BLMs right?) in the car's ECM. As I recall, there are a few ports (are they ports?) open on the ECM such as MAP2 and some other things. Could I wire a sensor for the cutout into one of these ports? How is this accomplished? and how would I setup the additional table for the fuel enrichment?
Thanks so much
Tony
Old Apr 21, 2003 | 08:25 AM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
If you have source code, you can do virtually anything.
Old Apr 21, 2003 | 08:53 AM
JPrevost's Avatar
Car: 91 Red Sled
Open exhaust and your Vol eff goes up in your cam/head selected powerband, elsewhere it might be higher or lower. That's what I've seen happen. Like Glenn said, source code and it's a reality.
Old Apr 21, 2003 | 12:29 PM
TonyC's Avatar
Car: A Camaro
Engine: Weak
How would you actually hook the voltage signal up to the ECM? Would you have to solder a wire to one of the prongs comming off of the chip (not on the actual prong, but on the wire comming off of it)
Old Apr 21, 2003 | 04:16 PM
Ed Maher's Avatar
Car: 04 GTO
Transmission: M12 T56
No, you'd take the signal in on an unused port on the ECM. From there you modify the code to read that port and then have it inject extra fuel, or change the timing, or whatever you want. You know what would be really cool. Make it flash the SES light when the cut-out is open too so that you can tell your passengers "uh oh, all hell is going to break loose now"
Old Apr 21, 2003 | 04:45 PM
Car: Death Mobile
Engine: 666 c.i.
YES! Make sure the wife is in the car so you can explain how the "rollikin rod just broke the bullgen bearing and the only way to fix it is to remove (insert the name of part you want to change) and replace it with (insert the name of part you want to install)".
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
InfernalVortex
Apr 20, 2021 11:31 AM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
dusterbd
Sep 29, 2015 08:40 AM
1HotZ28&SS
Sep 28, 2015 08:58 PM
