what cable?
Old Apr 22, 2003 | 10:11 PM
SlowMaro's Avatar
what cable?
what cable do i need to hook my pc to the aldl?? where can i get it?? --dont tell me to buy a lap top, il borrow one lol --
Old Apr 23, 2003 | 12:01 AM
jonarotz's Avatar
Car: 91 Z28
What type of program are you wanting to use? A two transistor will work with most programs. Go to http://moates.net select "software" and scoll down Craig has a couple of different schematics. If you are just wanting to buy one you can go and check out AKM cables.
Old Apr 23, 2003 | 12:15 AM
SlowMaro's Avatar
i ment what cable to attatch from the aldl in my car, to the back of the computer, to run diagnostics, timing settings, etc etc, im not trying to write my own proms or anything, just trying to check some stuff out thats going on with the engine
Old Apr 23, 2003 | 07:36 AM
Scott_92RS's Avatar
Car: 1992 RS
Engine: 406 Stealth Ram
http://www.winaldl.webhop.net
Has the software and the link cable schematic. This software and cable works on your TBI car.
Old Apr 23, 2003 | 09:32 AM
jonarotz's Avatar
Car: 91 Z28
Yeah, the 2 transistor cable is the easiest to build, and connects to your ALDL and plugs into your COM port on your laptop.
Old Apr 23, 2003 | 09:34 AM
jonarotz's Avatar
Car: 91 Z28
I might be wrong but you may not be able to use the Winaldl because it is for the 160 baud ecms. I am not sure about the tbi but Tpi uses 8192 baud rate ecm. Try Craig moates software or Datamaster.
Old Apr 23, 2003 | 09:44 AM
Scott_92RS's Avatar
Car: 1992 RS
He has a TBI car, unless his sig is innaccurate. The 2-Transistor cable and Craigs software are for 8192 baud ECMs.
Old Apr 23, 2003 | 10:03 AM
SlowMaro's Avatar
nah my sig is correct
Old Apr 23, 2003 | 10:10 AM
Scott_92RS's Avatar
Car: 1992 RS
Cool, then yuo can use the link I posted above. I have used both the cable and the software successfully on my 92 RS, with a 305 TBI. Good luck!
Old Apr 23, 2003 | 10:13 AM
jonarotz's Avatar
Car: 91 Z28
Cool, I learned something. I wasn't sure what the TBI cars ran. Now I know thanks.
Old Apr 23, 2003 | 10:17 AM
SlowMaro's Avatar
this will retrieve engine running data?? im not trying to burn my own prom, just trying to see engine specs..
Old Apr 23, 2003 | 10:23 AM
Scott_92RS's Avatar
Car: 1992 RS
Yes, it will give you all the info you need. Speed, RPM, SES Codes, 02 values, all that stuff. Check out the site, it'll tell you all you need to know.
Old Apr 23, 2003 | 10:28 AM
SlowMaro's Avatar
lol anyone wanna build me a cable??please?? ill pay ya and all for your time and the pars and all.....
Old Apr 23, 2003 | 10:38 AM
Scott_92RS's Avatar
Car: 1992 RS
The cable is EZ to make. Do you know anyone with a soldering pen? It will take you litteraly all of 20 minutes to make one up, probably including the trip to radio shack for the parts
Old Apr 24, 2003 | 08:50 AM
kevinc's Avatar
Car: 1982 Z28
Andrew Mattei wants to build you a cable...and you can pay him for his time and materials.
http://www.akmcables.com/ic.htm
Old Apr 24, 2003 | 12:16 PM
SlowMaro's Avatar
cool deal i just emailed him, thanks :hail:
Z28/ZR1
Oct 23, 2015 01:04 PM
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
TMZIrocZ350
Oct 7, 2015 12:09 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
rs_z28_vert
Sep 30, 2015 09:47 PM
