No Power
Old May 1, 2003 | 08:28 AM
Firebird sweden's Avatar
Car: Firebid Cab-92/1989 TTA
Engine: 383 HSR TPI
Transmission: TH700r4
Axle/Gears: 4.10
No Power
Hi!
I cant get the car go strong after mods it feels real weak ower all.
And it goes ritch on fuel to but a friend are coming over this wekend and we will run the win ALDL and he can burn the chip right a way.
But my cuestion to you are if the car can go so bad only depending on a bad chip or will it be something else,please respond if you have any comments.
Thanks!!
Anders
Old May 1, 2003 | 09:07 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: No Power
Originally posted by Firebird sweden
Hi!
Thanks!!
Anders
Looking at your list of mods you do need a lot of tuning. Off hand I'd say rich down low and lean up top. May find the 65's are small unless you bump the fuel pressure/volume.
Also going to need some help in the SA area.
RBob.
Old May 2, 2003 | 12:33 PM
Engine: 383 HSR TPI
Axle/Gears: 4.10
Hi!
Today I got help from a gy who could burn my chip and I was supriced of how things turned out.
At the first run the car was ritch on fuel byt second burn of the chip that was fixed but still not that power you looking for.
After the fourth run whith WIN ALDL we came close to perfect and the car runs strong from 1500-5000 rpm whitout any backfire or nothing.
So my experience are dont waste any time to adjusting the engine unless you have the oppotunity to burn a chip it solved all of my problems anyway.
I am going to have the car dyno soon.
By and thanks!
83 Crossfire TA
Jan 3, 2016 01:26 PM
my86bird
Oct 23, 2015 12:20 PM
Gunsbee
Sep 7, 2015 07:10 PM
Slush92RS
Sep 2, 2015 08:56 PM
z28guy134
Sep 1, 2015 11:50 PM
