ARAP BIN Question
Old May 22, 2003 | 02:21 PM
IROCKER's Avatar
ARAP BIN Question
If this question has already been asked than I apologize for being repeatitive and please direct me to the right thread or info.
I have an 87 IROC-Z with a 350 TPI and 700R4. I thought about trying the ARAP bin on my car, but will this work? I'm not sure if the ARAP was designed for a MAF or SD setup. If the ARAP is not applicable, are there any recommendations? A friend of mine has all the burner equipment needed, so I'll be getting him to make up the EPROM for me.
Old May 22, 2003 | 04:38 PM
needanother1's Avatar
You can try ARAP on your car. Be aware that your '87 has the cold start injector, and ARAP is for like an '89, without the cold start. I simply have the electrical connector on mine unplugged for now. They do make plug kits so that you can remove the cold-start injector for good, if you wish. In order to get quick start-ups especially when cold, you'll have to make some changes to the "crank fuel PW vs. Dist reference pulse" table. In the unmodified ARAP bin, it doesn't give the engine any fuel until the eighth pulse from the distributor, which will produce a long crank before the engine fires.
You should also keep in mind that the spark advance tables in the ARAP.bin are rather agressive, and were intended (I think) for aluminum heads. To be on the safe side, you might take the values down 8-10 degrees on the high load areas to see how your car reacts.
That's my opinion anyhow. Someone more experienced than me may have some better advice.
Jason
Old May 22, 2003 | 05:33 PM
primo's Avatar
Make sure to disable VATS.
Old May 22, 2003 | 05:51 PM
goneracin's Avatar
You can use the arap bin for an 87. Like others have said, you have to disable vats, remove the cold start injector, and you also have to change a flag for the fan opperation. It is reversed in the newer bin file. ARAP has a buttload of timing in it. I have burned many many chips working with the timing tables. The fastest way to get the timing might be to get a copy of the aujm bin, copy the timing tables straight from it into the arap bin.
Old May 22, 2003 | 08:14 PM
IROCKER's Avatar
All very good advice guys, thanks!
needanother1: That's what I figured I'd do with the cold start injector, is just disconnect it for now to try it out. I curious, what would happen if it was left plug in? Rich condition? Code thrown?
Primo: Thanks.
Goneracin: What is the AUJM bin and does it offer any performance? Or is it just a stock bin used to get the timing table from?
Old May 22, 2003 | 09:12 PM
goneracin's Avatar
AUJM is, I think, an 89 350 bin. Has a more real world timing table. You can just unplug the cold start inj, but if it ever develops a leak, its gonna run very rich. I would remove it if you are going to stay with the later model ecm file ($63 vs $32). Its not needed, and can cause a problem.
Old May 23, 2003 | 09:28 AM
IROCKER's Avatar
I'm curious what happens if you leave it plugged in? Do you get a code thrown? Leaking?
Old May 23, 2003 | 02:56 PM
Morley's Avatar
No code but it may flood the engine on start. If you want to leave it in place and hooked up, just remove the crnk fuse from the fuse block, all that fues does is run the coldstart system.
Old Jul 16, 2003 | 06:46 PM
jo88gta's Avatar
Car: 88 GTA
Engine: 355 TPI
Transmission: 700 R4
Axle/Gears: 370 BW
I found the ARAP BIN's timing a little extreme for daily driving as well. Tried the AUJM and found it way to mild for daily "performance" driving. The one that worked best for my car was APYP which appears just about in the middle of the ARAP and AUJM timing tables.
Each car will be different, but I took the ARAP BIN and swapped the timing tables from the other two until I got a good starting base. From there I used the scanner and tweaked the table for optimal performance. Actually, that seems to be a never ending task.
Just something else you can try.
tealman92
Exterior Parts for Sale
Aug 27, 2015 11:21 AM
Omega
LSX and LTX Parts
Aug 26, 2015 06:40 AM
beast94
Aug 20, 2015 06:44 AM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
