Changed injectors, runs rich in open loop?
Old May 31, 2003 | 12:31 PM
ZaphodB's Avatar
Car: Camaro IROC-Z '89
Engine: 350 TPI /w Procharger P1SC
Transmission: TH700R4 with Transgo shiftkit
Axle/Gears: 2.77 Borg Warner
I have changed my #22 original injectors to Accel #24 injectors, and adjusted the injector constant to 25.83 @ ~46 PSI.
The car runs great, and I have borrowed an emissions sniffer and tested it, seems to pass good with this setup... (HC 20/100, CO 0.02/0.5, O2 1.11/1.25).
But, it smells like the car runs rich right after I crank it, what is the best way to fix this? I am running a mildly modified version of my original ANYJ chip.
Old Jun 1, 2003 | 12:32 AM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
That can be kind of a sticky wicket area.
It can be rich from the prime start signal. or from the first run stuff.
If it's from the prime signal there are several easy things to try. One is the base pulse width for crank. Then CTS crank PW correction, and then there is the crank PW vs ref pulses. I'd first try the base pulse width for crank correction.
Then if it's from the first run area then you might lean down the MAF area at the lower then normal idle gm/sec area of table one. ie if your normal idle air is 7 gm/sec, then at the less then 6 gm/sec area try leaning down a LITTLE.
MustangBeater20
Oct 29, 2022 09:20 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Jae992
Aug 27, 2015 09:07 AM
kyleb24
Aug 15, 2015 08:24 AM
squiggy2
Aug 9, 2015 09:30 PM
