Idle requested RPM (scanner) vs Target idle RPM (calibration)
Yesterday, I was trying to lower my idle speed on TunerCat from 675 rpm to 625. But when I burned the chip and put it in, the scanner was showing that the computer was still requesting a 675 rpm idle speed. I repeated the process several times but could not get the computer to alter it's idle speed request. I also went back and cleaned the IAC, then changed to another IAC I had lying around, and performed the manual idle speed adjustment multiple times. No matter what I tried, it would not drop down past 675 rpm.
Anybody experience anything like this?
Car: check
Engine: check
Transmission: check
Re: Idle requested RPM (scanner) vs Target idle RPM (calibration)
RBob.
Yeah, that would help woundn't it?
It's a 7730 ECM and (not sure of the mask I.D.) it's based on an AUJP calibration.
I tried changing the "add rpm to Park/Neutral" value to zero. But the ECM wouldn't accept change that either.
Car: check
Engine: check
Transmission: check
Code:
LDAA L005D ; FLT COOLANT TEMP
LDX #L8632 ; IAC CMD SPEED vs COOL TABLE
JSR LE3D0 ; 2D LOOK UP, NO OFF SET
TAB ;
BRCLR L00FE,#$80,LC269 ; BR IF NOT b7, PK/NEUT, 1 = NEUT
; (IAC Md Wd #2)
; .... else
ADDB L862E ; 100 RPM ADDED IF IN PK/NEUT
LC269: BRSET L00FD,#$80,LC270 ; BR IF AC STATUS OFF
ADDB L8630 ; 12.5 RPM ADDED IF A/C ON
LC270: BRCLR L003A,#$08,LC27E ; HOT RE-STRART RETARD OFF
LDAA L0063 ; Linear MAT value (from tbl)
LDX #L8673 ; HOT RESTART CMD SPEED vs MAT TBL
JSR LE3D0 ; 2d LOOK UP, NO OFF SET
ABA ;
TAB ;
LC27E: ADDB L01B5 ; DIFF DESIRED RPM FOR LOW BATTERY Code:
L8693: FCB 120 ; ADD O.S. TO DESIRED RPM IF BATT =< 12.0 V
L8694: FCB 135 ; SUB O.S. TO DESIRED RPM IF BATT > 13.5 V
L8695: FCB 5 ; ADD OFFSET IF BATT LO 5 SEC'S
L8696: FCB 1 ; ADD 12.5 RPM TO OFFSET IF BATT LO
L8697: FCB 20 ; CLR BATT IAC WHEN Vss > 20 MPH
L8698: FCB 8 ; LIMIT IAC OFFSET FOR LO BAT TO 75 RPM.
; ARG = RPM/12.5 RBob.
I don't recognize some of those parameters from TunerCat.
All I can locate that affect RPM at idle operation are:
Idle speed vs Coolant temp - 625 rpm
Add to RPM in Park/Neutral - 0
Add to RPM with A/C on - 0 (no A/C on my car)
Car: check
Engine: check
Transmission: check
OK to the prk/neut & A/C, eliminates those variables. That leaves the battery voltage and hot restart MAT corrections to check. Can either add the parameters or use a hex editor to check/change them.
RBob.
Car: check
Engine: check
Transmission: check
Thanks for the info. But I haven't delved deep enough into the program to know how to do Hex editing.
What is entailed in that?
For hex editing, search the diy-efi archives. It isn't something to be taken lightly. You'll neeed to do conversions yourself and plug them into the proper EPROM bin file location.
RBob.
Car: '90 Iroc
Transmission: 5 spd
Originally posted by RBob
The idle speed vs coolant should be a table that covers a range of coolant values. Make sure that the coolant is at the proper temperature for the desired idle spd.
RBob.
RBob.
Eric2ndGen
Aug 31, 2015 12:33 AM
