BCC look up plz
Old Jun 30, 2003 | 10:25 AM
BitchinCamaro's Avatar
BCC look up plz
I hunted around the net and couldn't find it, hopefully you guys can help me out Its a 730, BCC is ASMT. Its a reman'ed unit. Thanks guys. :hail:
Old Jun 30, 2003 | 02:41 PM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
It's for 1987(ish) A-body (Celebrity, 6000, Cierra, Cutlass & Century) with 2.8 V6 Auto.
Cannot use it for V8 applications.
Old Jun 30, 2003 | 03:29 PM
So can I still use the ECM if I get the correct Memcal? Its a 01227730. Or should I just trash the whole thing and start digging through the local bone yards Thanks again!
Old Jun 30, 2003 | 04:00 PM
shaggy56's Avatar
Car: 71 Nova
Engine: Superramed 383, Topline heads
Axle/Gears: 8.2 posi 3.08
Im not %100 but I have heard the the ecm is identical its just the memcal that would need to be replaced as that is what is different between a v8 and v6. Maybe someone else can give you second opinion.
Old Jun 30, 2003 | 08:35 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
Re: BCC look up plz
A 1227730 is a 1227730.
The calibration in that particular one, is useless, for use in a V8.
You just need to buy a memcal for a v8 to work with.
The calibration defines the application.
Old Jun 30, 2003 | 08:50 PM
JP84Z430HP's Avatar
Car: 84 Z28
Engine: 355 (fastburn heads, LT4 HOT cam)
Axle/Gears: 9-bolt, 3.27
OMIGOSH! I think this just answered a question I was about to ask, and I may post if I don't get a response.
If I had a V8 memcal, I can't just change the flag in the bin to make it work with a V6? What I'm wanting to do is use a 1227165 on my 2.8 S-10. I want to do this to get started on burning chips before I get to the Camaro. I was planning on using a '165 with a 4 cyl code base (uses MAP not MAF on a 4 cyl) , and modifying it to run a V6. I would only have to change like 2 or 3 pins in the connectors to do this! I prefer the 165 ECM for my "Experimentation" since it's a P4 (More advanced?) and one of the possibilities for the Camaro when I get to putting EFI on it.
If this won't work, I guess I have to find a 4.3 AT bin for a 1227747 ecm. That one is a direct plug-in, in fact, I tried out one from a C-1500 (Actually was the newer 16144288, but all the wiring is the same) and it started and ran, but no A/C. I think the 4.3 Blazer from 1990 with AT will do what I want, I just need to find the correct bin.
I have access to all the wiring diagrams I need to do virtually any swap, so any ideas are appreciated!
Old Jul 1, 2003 | 08:19 AM
Car: Death Mobile
Engine: 666 c.i.
Why not use a 7730 with a V6 Memcal? 7730s are cheap and plentiful and easy to find. In fact, you are very likely to find a V6 Memcal that will work as well. V6 Memcals are the most common Memcal when you find a 7730. Many wrecking yards just toss those away.
Old Jul 1, 2003 | 05:46 PM
shaggy56's Avatar
Car: 71 Nova
I believe this topic was discussed why you cant use a v6 memcal with a v8 engine and visa versa. The main reason is in the knock circuitry is specific for each application by cylinder volume and should not be mixed for best performance.
Old Jul 1, 2003 | 08:42 PM
JP84Z430HP's Avatar
Car: 84 Z28
Yeah, sorry I haven't researched it yet, I was just reading this and thought I saw a light bulb light up for me!
Glenn,
The main reason for not going to a 7730 is the amount of rewiring needed for something that will be temporary. The 7165 is close to the same pinout that I need, I thought it might work. I actually have a 7730 on the shelf at work waiting for something to do, and I have a MEMCAL from a 2.8 MPI (MAF) car. Now, if I was to tackle this task, I would just use that MEMCAL and load up a .bin for a MAP application, and wire it accordingly? I may consider doing this! It would at least get me going on burning chips and learning some!
I suppose now I'm off to find some of the discussions on the differences in the v6 and v8 MEMCAL's, or is there even anything more in-depth than what has already been stated in this post?
Thanks for the help
gixxer92
Apr 12, 2022 12:09 AM
david068513
Sep 18, 2015 10:36 AM
inferno15
Aug 29, 2015 01:48 AM
SMasterson
Oct 16, 2001 01:15 AM
