winaldl and 730
Old Jul 6, 2003 | 07:07 PM
billyhoss's Avatar
winaldl and 730
will winaldl work with the speed density ecm 730? i can not find it in the ecm directory in winaldl, and if it does not what ar hte ppl with a 730 using for data logging so set up a custom chip for burning. thanx for ur time
Old Jul 6, 2003 | 07:26 PM
mmcdjs's Avatar
Car: 1991 Pontiac Firebird
Engine: 3.1 V6
SD
Hey, I've been wondering the exact same thing! I have the 3.1L mpvi SD 730 ECM. I have really modified the engine and now it can't keep up. I want to install 19# injectors and take out the speed limiter too. Can you let me know if you find a program that works?
thanks
Old Jul 6, 2003 | 09:29 PM
Scott_92RS's Avatar
Car: 1992 RS
Engine: 406 Stealth Ram
as far as I know, WinALDL only works with 160 baud ECM's. Check out www.moates.net and download his software, and make the 2-transistor cable, and you'll be able to link up to a 730 ECM (8192 baud).
Old Jul 6, 2003 | 10:02 PM
shaggy56's Avatar
Car: 71 Nova
Engine: Superramed 383, Topline heads
Axle/Gears: 8.2 posi 3.08
Datamaster works great for datalogging and has lots of cool options and works with the 2 transistor interface. I believe the trial version gives you a limited number of datalogs. I was lucky enough to aquire the full version and it is awesome. I especially like the way it illustrates your lean and rich condition through a histogram and you can easily make adjustments with a simple editor through your ve tables. Has other neat features like a dyno and 1/4 mile calculator.
junkcltr
26
Jan 22, 2022 10:53 AM
F.I. 57 Belair
Aug 23, 2021 01:09 AM
Azrael91966669
25
Jun 20, 2017 04:04 AM
355tpipickup
Aug 19, 2015 10:02 PM
HighHopes85
Dec 3, 2001 06:28 PM
