commander 950 VS. Eprom programming
Old Jul 7, 2003 | 01:19 AM
MYBLUZ's Avatar
Car: 1991 Z28 1LE A.K.A The blue rocket
Engine: Blown 383
Transmission: Full manual 700R4
I was wondering why most people burn their own chips instead of running a commander950 like system? Is it the $900 price tag? Its seems that even though its expensive as hell, thats its so freeking easy to tune. Driving down the road, realtime, at the track.......
Old Jul 7, 2003 | 08:09 AM
CrazyHawaiian's Avatar
Car: too many ...
Its mostly the price. If you stick with the GM equipment and tune yourself, you can actually enjoy alot of the benifits of a system like the Commander 950, but at 1/2 the price or even less. Set up a romulator and you can tune the GM ECM in real time while driving down the road. You can even get a wideband 02 sensor setup for cheap (like $200) and tune your A/F ratio's. The difference between the two is one is packaged nicely and easy to understand, the other needs to be pieced together and takes some time and effort to understand. If you are a DIY kind of guy then choice two is the best. For me the cost difference was the deciding factor. The money I save will pay for my new intake.
Old Jul 7, 2003 | 09:27 AM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
Re: commander 950 VS. Eprom programming
None of the aftermarket ecms that I know of have the R+D facilities of GM. The 730 ecm used in the 90-92 set an industry standard. It's really hard to beat it for reliability, and flexibility.
Pop an injector driver in a Commander, and the car just sits waiting for a replacement. pop a GM ecm and go to the local junkyard and for $50 your on the road again.
While at one time the aftermarkets were easier to program, the drivibility was just slightly better then terrible. But now, to get the drivibility right, they've gotten more complex.
Real Time for the novice can be alot more of a disadvantage then an advantage.
Tuning is about noting trends, with prom burning you have to take the time to burn the chip, and hopefully write some notes about what you saw or learned. It's easy with real time to overshoot something, and get lost in the tune.
There are times when they have an advantage, but in general for anything that's really a street car, they don't have alot to offer.
Old Jul 7, 2003 | 11:08 AM
hectorsn's Avatar
Car: 78 Regal
Engine: 82 FBod LG4 305, 730 ECM
Transmission: M20
Axle/Gears: 4.10
I think this is also another one of those marketing things. The advertisements have you thinking it's going to be exactly what they say. Just like those performance chips that folks swear by. I mean, to quote "easier to tune" doesn't really say anything. Most people here burn proms because that's what they have in their cars. Some burn proms because they know they don't "need" an aftermarket system. Some burn proms because it is cheaper. Some burn proms because the factory ecm is better than the aftermarket for their application. Some don't burn proms but tune "on the fly" and then burn a prom when all is said and done. I'm sure there are even more reasons then the ones I just stated but I won't go any further. There is a time and a place for an aftermarket ecm as I won't sit here and tell you they aren't needed ever. It's just that most folks here have seen the truth about certain advertising tricks and don't care to be fooled by them. Notice that in every car magazine article they have used an aftermarket ecm that is so "easy to tune", they have taken it to a "pro" tuning shop. If it's so easy, why didn't they do it themselves? Don't do like many of us (myself included) have done and buy the hype. Research and buy what you need.
Old Jul 7, 2003 | 04:41 PM
88TPI406GTA's Avatar
Car: 2009 Pontiac G8 GXP
Engine: LS3
Transmission: 6L80E
When I checked out the Commander 950...I found that it only controlled the ECM...not the transmission or any VSS input. I want that control from the GM ECM and am not willing to pay for an aftermarket ECM.
With Moates software, a Pocket Programmer and my Romulator...why spend the $$$ with the aftermarket when you don't have the ease of replacement, and the Holley has less control than the GM unit?
HTH,
Old Jul 8, 2003 | 11:14 PM
MYBLUZ's Avatar
Engine: Blown 383
My 700R4 is fully manual, so tranny controls wouldnt be a prob, but I am not sure what vss input is. Does that have to do with the speedo controls? I have heard that you lose that with the commander950 system, which is a HUGE turn off. I have already purchesed a eprom programmer, but I'm having problems downloading the software off their web site. Needless to say this is discouraging. If I can even load the software, I dont even want to touch it. Thanks.
Old Jul 9, 2003 | 05:28 AM
JohnL's Avatar
VSS is vehicle speed sensor. Your Delco ECM gets a signal from it as part of the idle control system. Without it, you may find yourself stalling as you coast to a stop. It also affects other stuff like DFCO (deceleration fuel cutoff. I've got no idea what happens with this in your C950 whatsit.
John
Old Jul 10, 2003 | 11:42 AM
MYBLUZ's Avatar
Engine: Blown 383
The more I read about the 950 the more I dont like it. I would like a system that is adjustable on the fly, but am not willing to lose my speedo. I mean come on, how many stories start '' I was doing 135.....''
Old Jul 11, 2003 | 06:05 AM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
Was at 5,400 RPM, 18 PSI, in high gear with the converter locked so that woulda been about 145-150...........
LOL
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
seiplentz
Aug 19, 2019 06:02 PM
ULTM8Z
Oct 2, 2015 01:25 PM
BBSDesigns
Sep 22, 2015 03:08 PM
3.8TransAM
Sep 17, 2015 02:16 PM
