My ECM over-heated!!
Old Jul 16, 2003 | 08:37 PM
Low C1500's Avatar
Car: 89 Shortbox
Engine: 350 Vortec
I went to start the motor, and it went into limp-mode right away, I tried everything to fix it - with no sucsess. I opened my glove box (which happens to be black , along the rest of my interior) and the ECM was to hot to touch, from the sunlight. So I stuck it in the freezer for 10 min, and everything was fine after that.
Just wondering if this has happened to anyone else, also I can't figure out why it wouldn't work when its really hot.
Old Jul 16, 2003 | 08:43 PM
JP84Z430HP's Avatar
Car: 84 Z28
Engine: 355 (fastburn heads, LT4 HOT cam)
Axle/Gears: 9-bolt, 3.27
That's a common failure of an ECM. When I used to work at a dealership, I had replaced many ECM's because of this. What I believe to be the problem is that the heat causes things to expand, and some things break connection.
Old Jul 16, 2003 | 10:22 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
Re: My ECM over-heated!!
I wouldn't be counting on that ecm.
In the ecms I've tested to distruction none of them healed after overheating them. Once they were used, again and again the temps always lowered to where they would act up.
Generally it's the injector drivers that fail first.
Old Jul 16, 2003 | 10:38 PM
funstick's Avatar
and to think id be looking for a short + to the injector wiring pre injector or a internally shorted injector.
Low C1500's Avatar
Car: 89 Shortbox
Engine: 350 Vortec
Thanks guys, I'm gonna grab a spare ECM to pack under my seat, form the auto-wreckers.
InfernalVortex
Apr 20, 2021 11:31 AM
Falcon50
Aug 22, 2020 03:26 PM
thunder57
Nov 7, 2015 02:28 PM
Jlanz55
Sep 29, 2015 08:55 AM
efiguy
Sep 27, 2015 01:30 PM
