Hey chip burners ever have this problem??
Old Jul 18, 2003 | 04:32 PM
Camaro91S's Avatar
Car: 91 Camaro RS
Engine: 350 C.I.
Transmission: 700R-4
Well I have a performance chip I wanted to try so I put it in and it makes my transmission change gears way to early so I went to put my stock one back in and I tried to start my car and it only starts up and then it goes dead in 2 seconds, what the hell happened to my chip?? Why does the performance chip I bought make the transmission act funny??
Old Jul 19, 2003 | 10:32 AM
knoxbonnie's Avatar
Did you disconnect the battery or pop the ECM fuse while you were swapping those chips around?
Old Jul 19, 2003 | 05:17 PM
Camaro91S's Avatar
Car: 91 Camaro RS
Engine: 350 C.I.
That is what I done
Yea, that was my first time pulling the prom out, forgot to disconnect battery. Trying to get started burning my own chips, not getting off to good start. Car wont run without a chip that works, I have learned that already.
Old Jul 19, 2003 | 07:34 PM
knoxbonnie's Avatar
I just started burning my own as well. I got the Moates Adapter and a PP2. With the Moates adapter, I have swapped out my 29c256 chips successfully several times without removing power from the ECM.
What are you using to burn your chips with?
Old Jul 19, 2003 | 07:54 PM
Camaro91S's Avatar
Car: 91 Camaro RS
Engine: 350 C.I.
stopped before I even got started
Well I was going to order the Xtronics pocket programmer but not sure exactly what is the easiest to work with. How did you decide what you were going to use? Where did you order from? I was just checking out how easy it was to change out proms since I had one sitting around that was supposed to be better than stock and it wasnt. I am really wanting to get started but not sure what is going to be easiest for me to learn with.
Old Jul 19, 2003 | 11:22 PM
knoxbonnie's Avatar
Go to http://www.moates.net/ I just followed all of his reccomendations. And so far, everything has worked flawlessly for me.
Ghettobird52
Jul 5, 2024 11:18 PM
Infested
May 22, 2018 11:56 PM
LT1Formula
Nov 16, 2015 01:13 PM
Red iroc-z 305
Sep 30, 2015 05:22 PM
nhra-trans-am
Southern California Area
Sep 17, 2015 10:16 PM
