Maybe a bad question but.....
Old Jul 30, 2003 | 01:19 PM
GofasterFirebird's Avatar
Car: 1991 Firebird
Engine: 427 LSX
Transmission: Turbo 400
My 406 runs better when it is in closed loop. Little if any off idle hesitation, popping, etc. But closed loop enters and everything changes. Lots of tip in issues, popping out the exhaust, etc. The O2 sensor is 6 months old. My Blms are anywhere from 122 to 132. Am I missing something? Shouldn't the car run better when the ecm is correcting with the o2 sensor? Thanks
Old Jul 30, 2003 | 06:37 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
Re: Maybe a bad question but.....
128s only signify, having the light load fueling correct.
Timing can still be miles off, as well as any of the higher level fueling requirements, as well as transistional fuel.
128s are a start, not a sign of completion.
Old Jul 31, 2003 | 09:15 AM
Car: 1991 Firebird
Engine: 427 LSX
OK, so I assume that timing at part throttle changes with closed and open loop?
Old Jul 31, 2003 | 10:18 AM
funstick's Avatar
there could be some sort of tempature based spark adder that your overlooking thats in play when your in open loop and not having these troubles. typiclly when you hit closed loop alot of the cold run mode and open loop spark adders turn off.
Old Jul 31, 2003 | 01:13 PM
87_TA's Avatar
There are three tables that may be affecting that.
Open loof F/A ADDER VS TEMP.
--------------------------VS MAP.
BASE COOLANT ADV.COORECTION VS. LOAD VS. TEMP.
Old Jul 31, 2003 | 05:54 PM
Car: 1991 Firebird
Engine: 427 LSX
87, I am running your chip slightly modded!
Old Aug 1, 2003 | 04:53 AM
87_TA's Avatar
Ohh LOL..
What cam are you running, LSA,DUR @50? and what size inj?
Is this a Mini Ram engine?
Old Aug 1, 2003 | 06:51 AM
Car: 1991 Firebird
Engine: 427 LSX
It is a comp cams custom 240 240 hyd roller 112 lsa. I converted an LT1 intake, so it is probably the same or very similar to the mini. Also, I have 30 lb SVOs.
Frozer!!!
Jan 19, 2024 04:55 PM
chazman
Aug 28, 2018 03:25 PM
chazman
Aug 22, 2015 02:01 PM
Bryan F
Aug 18, 2015 02:28 PM
redmaroz
Aug 16, 2015 11:40 PM
