help, please answer
Old Aug 7, 2003 | 12:34 PM
lucassays's Avatar
help, please answer
i am swapping in a tpi setup from a 91 tpi 305 5spd. it is going into a 84 z28 HO 5spd. the cams are different. does this mean that i need a new prom for the computer, or will it work just fine? please get back to me. thank you in advance.
Old Aug 7, 2003 | 01:49 PM
SATURN5's Avatar
Car: 84 SVO
Engine: Volvo headed 2.3T
Transmission: WCT5
Axle/Gears: 8.8" 3.73
Re: help, please answer
It will probibly run.. but not be 100%.
Old Aug 7, 2003 | 02:28 PM
lucassays's Avatar
what should i do? is there a place i can order the correct chip from? or will i be forced to buy all the stuff to make my own? please help me im really in the dark. thanks for replying
Old Aug 7, 2003 | 02:52 PM
MonteCarSlow's Avatar
Car: 1988 Monte Carlo SS
Engine: 5.7L TPI
I did a similar swap to my Monte Carlo SS. The 91 calibration is close enough if your 305 HO is stock (i.e. no headers, gutted cat, etc). No guarentees though. Just what worked out for me. The 305 H.O. cam is very similar (same?) to the 1985 305 TPI cam.
Edit: FYI, I didn't leave the chip stock...
Old Aug 7, 2003 | 05:18 PM
lucassays's Avatar
yeah, the 85 tpi cam is almost identical to the 84 ho cam. i was wanting to put on headers. where can i get a chip made for my application?
Old Aug 7, 2003 | 05:58 PM
SATURN5's Avatar
Car: 84 SVO
Transmission: WCT5
Anything over the counter will be just as bad as the stocker.
Bite the bullet, and get the gear, or locate someone near you that can burn a prom for you.
You will be miles ahead in doing so...
grngryoutmyway
Oct 18, 2016 05:48 PM
cheesehomer
Dec 31, 2015 08:48 AM
HoosierinWA
Oct 7, 2015 10:15 AM
kkirch15
Sep 30, 2015 04:44 PM
92projectcamaro
Sep 29, 2015 07:07 PM
