Last Rites, Death in the Family.
Old Aug 14, 2003 | 11:26 PM
Craig Moates's Avatar
Car: 87 T/A
Engine: 441 SBC 12.5:1 0.680" Lift
Axle/Gears: 4.10 TruTrac Moser 9"
Yes, this is bad.
Click here for details:
http://moates.net/mainframe.htm
This is my child, torn apart from the inside out.
Keep this in mind the next time you choose parts.
Hey, at least it was tuned good!
Old Aug 14, 2003 | 11:39 PM
The_Raven's Avatar
Car: 1985 GMC Jimmy/1998 Chevy Malibu
Engine: 3.2L turbo Hybrid/bone stock 3100
Transmission: T-5 soon to be 700R4/4T40E
Ouch!
Old Aug 15, 2003 | 12:31 AM
jayhah2's Avatar
Ewwwwwwww, like the post before that had to hurt.....
Old Aug 15, 2003 | 12:51 AM
Z_Ghost's Avatar
When you blow up a motor you really blow up a motor.
Old Aug 15, 2003 | 05:56 AM
TRAXION's Avatar
Car: 2005 Subaru STI
Engine: 153ci of Turbo Power!
Transmission: 6-Speed
Hey Craig. You said not to "skimp on parts". What parts did you skimp on? The valve springs? Which valve springs were you running?
Tim
Old Aug 15, 2003 | 06:49 AM
BOTLFED's Avatar
Man Craig, I feel your pain.. A couple years back I did the EXACT same thing... Bought cheap valve springs and paid for it ten-fold...
Pics and details of that are on my site for anyone who cares.. (see sig) Hope you're back up and running soon..
Cheers,
Old Aug 15, 2003 | 08:39 AM
Morley's Avatar
Hokey chit! Talk about self distruction.
Old Aug 15, 2003 | 08:53 AM
Black 91 Z28's Avatar
Car: 1991 Camaro Z28
Ouch...Hopefully it'll keep other from buying cheap parts.
David
Old Aug 15, 2003 | 08:54 AM
Bobalos's Avatar
Craig,
JB Weld & a new Coat hanger wont fix that right up? Well, maybe the piston hole, but might be hard to glue the tops of the valves back on. J/K.
Sorry for your pain amigo, Most of us have been there. I think my Buddy Marv says it best, "only a rich man can afford to buy cheap parts, because only a rich man can afford to replace them time, after time, after time". still sucks.
Bob
Old Aug 15, 2003 | 09:00 AM
Mutiny32's Avatar
Car: 1992 Camaro RS, Teal
Engine: 305 TBI, Soon to be 383 HSR
Transmission: Pro-Built 700R4
You're not cool until you can do it with a shoestring and a potato while powering the eastern seaboard.
Old Aug 15, 2003 | 12:46 PM
OMINOUS_87's Avatar
Those pics put the pain into the belly of anyone who views them. What is a quick breakdown of what you were runnning in it?
Old Aug 15, 2003 | 01:11 PM
2.73's Suck's Avatar
Car: 1985 Mustang GT
Engine: hamsters
Transmission: a hamster wheel
those pictures are gonna give me nightmares
Old Aug 15, 2003 | 01:22 PM
SATURN5's Avatar
Car: 84 SVO
Engine: Volvo headed 2.3T
Transmission: WCT5
Axle/Gears: 8.8" 3.73
damn thats some carnage....
Last engine I broke lost a rod bolt... blew the crank, a couple rods and pistons, and of course the block.
But that was a Ford 302.. still haven't killed a chebby.. yet. BW
Old Aug 15, 2003 | 05:17 PM
SMasterson's Avatar
Car: '89 GMC Pickup
Engine: 383 SBC Stealth Ram
Transmission: 700R4/VIG 3200
Sheesh! You're going to have to sell a lot of PROM adapters and EPROM chips to cover that! Got anything new that I need. I've got a few bucks I can lay on you.
BTW, you have GOT to tell us what brand of valve springs those are! (They were rated for your application, right?)
Sorry to see it buddy. My 383 rolled over 13k and two years just recently and still holding. Hits 7k pretty often and I hold my breath everytime! Sounds so good I can't stop it though.
Just to stay on topic. Hardly any of the original 3rd gen left except the hacked up 165 harness and the BBK throttle body.
Let me know. . .
Old Aug 15, 2003 | 06:22 PM
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
My condolences Craig!
Look at it this way, now you can do what I should have done in the first place:
LS-1 crate motor
ported heads
big-*** cam
MTI computer
reliability, over 400 at the wheels, and while getting 22 mpg !
Good luck and let us know what you decide to build next!
Mike
Old Aug 15, 2003 | 11:02 PM
Twilightoptics's Avatar
Car: '87 IROC-Z/'82 RX7
Engine: SBC 355/1.1L Rotary
Transmission: T56/5 Speed
Axle/Gears: 4.33/3.93
OUCH! What kind of Springs were those and then what did you punish them with?! Cam/RPMs!
SUCK!
Old Aug 15, 2003 | 11:20 PM
funstick's Avatar
i looked at the pics. a good machine shop, a sleeve, a new head, and a fresh piston could get it up and running without breaking the bank. doesnt look like the crank took any abuse so if the block is still mechanically sound then everything should be ok.
aside from the hole i saw every thing except the cylinder head looked repairable and to be honest ive seen some guys who could fix that to.
Old Aug 15, 2003 | 11:26 PM
Car: 87 T/A
I hadn't really revved it too terribly much. Usually brought it up to 6k and that was about it, even though there was lots more up top. I'm thinking that the outer spring was already broken/fatigued (it had been running kinda rough for a few days), and that the inner had kept it 'alive'. Should have inspected below the covers and not just changed plugs. Hindsight 20/20 right? Maybe.
OK, here was the 383 combo, starting with the springs:
1) Springs: Used (there's the mistake) Lunati 'green stripe' (also known as 'bad luck' springs I've come to find out) 1.550 set up at 1.900" and 170# seat. Also had lash caps.
2) Heads: Iron Sportsman ][ heads, 2.05/1.60, opened up, flow tested at 275/190. Fresh guides, etc.
3) Block: 010 high nickel 4-bolt 2-piece ca. 1979, .030 over
4) Crank: Scat 9000 externally balanced stroker
5) Rods: Scat 4340 Forged I-beam
6) Pistons: TRW/SpeedPro Powerforged, press-fit
7) Cam: Comp Cams small base circle solid roller 236/242@.050,.560I/.570E
8) Lifters: Comp Cams solid roller (especially for deeper galley requirement of SBC cam)
9) Rockers: Comp Cams ProMagnum 1.5 full roller
10) Pushrods: Comp Cams Magnum, good ones.
11) Timing: Billet Comp Cams set /w/ 'cast' aluminum cover, offset bushing for dial-in to 4 deg.
Total damage:
- Block shot
- One piston gone and others damaged
- One head gone along with 2 valves & 1 spring
- One rocker arm trunion bearing damaged / rough
- One pushrod bent
Stuff that MAY be OK:
- Rods & crank
- Timing set, cam, lifters, oil pan / timing cover
- All but one rocker, all but one pushrod
- Damper, flexplate, etc...
(Wouldn't be betting on that #6 connecting rod ;( )
I'm thinking on what to build next. Still going to make it 165 MAF-based. Looking for ca. 600hp this time on the engine. Stroked 400? Hmmm....
Maybe I can reuse some of the valve springs.... No, not really!
Muahahaha!
Old Aug 15, 2003 | 11:33 PM
funstick's Avatar
criag i can get in touch with people at world products and see how the durability is comming on the 454 motown build ups theve been doing. yeah a 454 SBC is the **** !!!! anyways theve got the parts now to do it. as for cylinders heads the pro line 18 degree heads would be on the top of my list or a set of nascar sb2's. you can pick those up from a few places. hell i would say if your gonna trash the block trash it all. if your shooting for 600hp and driveability i would consider looking at some with forced indution. or go for the biggest SBC you can scew together. at 454 CI the problem will be finding cylinder heads with enough port to feed the monster but i think worl products has head snow that are 220cc intake so that might nix the problem right there. anyways toss me an email i might be able to dig something up out here for you. and sorry to here about the engine going kaboom.
Did the gear set install go smooth ?
Old Aug 16, 2003 | 02:00 AM
3.8TransAM's Avatar
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
Dohhhhhhhhhhhhhhhhhhhhhhhh
Do i know that feeling :-(
Looks like your dampers started breaking and knock out everything else just like mine started too :-( I had to redo a head cause it was seeping oil on the outside and when i pulled the valve covers i found all my dampers had broke or wear fatigues and the formie vortec 350 soon got a rebuild . Went thru the pump obvioulsy and had shards all over in the engine but managed to catch it before catastrophic failure occured
I share your pain but hey look at it as an excuse to go bigger/faster :-)
LAter
Jeremy
Old Aug 17, 2003 | 10:04 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
There have been a few on-lines sources for ti keepers, then decent retainers, with Lunati springs.
I've lost faith in Comp cams and Crane.
The Comp 980s are junk, IMO. I broke some on a 5,200 RPM engine.
FWIW,
Sorry about the kid.
Old Aug 18, 2003 | 05:59 AM
TRAXION's Avatar
Contrary to what Bruce said I've seen nothing but reliability from the Comp 987 series springs. I personally know several people running them in applications from road racing to drag racing to double duty and tripple duty with street driving. Definitely not good for a solid roller application ... but definitely an awesome spring for a hydraulic roller application. I have a set of dynoed 987s that are going on my car. The matching titanium retainers should be here today and then I have to mic each location and shim as necessary.
As far as the motowns go ...
When my motor goes I'll be going the 427 shortblock route. The 454 is a great idea ... but they are getting that extra 27ci via the bore. Both the 427 and the 454 have the same stroke from Motown. The 454 gets overbored to the limit where rebuilding it might prove to be difficult. The 427 has tons of life left in it and can be bored over many many times.
Tim
Old Aug 18, 2003 | 12:06 PM
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
Actually, the 427ci motown block can be bored and stroked to 500 cubic inches!! :hail: Thats right, a 500 ci. SBC ! I have the build up in one of my chevy high performance mags.
I still say save up for a 382 ci all-bore heads and cam LS-1. 500+ horsepower and 22 mpg with great street manners is hard to beat!
Old Aug 22, 2003 | 03:35 AM
darkhorse91's Avatar
Car: 91 B4C/91 RS 305
Engine: L98 and L03
Transmission: 2xTH700R4
Axle/Gears: 3.23 LSD/2.73 Open
I'm not seein' any pics
Old Aug 26, 2003 | 10:49 AM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
ditto..
Old Aug 26, 2003 | 05:08 PM
Car: 87 T/A
http://www.moates.net/gmecm/death/
Old Aug 27, 2003 | 07:20 AM
justme's Avatar
OUCH! Hope that engine killing disease isn't going around! Makes me want to swap springs just for the hell of it.
Old Aug 27, 2003 | 09:15 AM
Ken73's Avatar
Car: 82 Corvette
Engine: 350 CrossFire
Craig, would you mind telling us what parts you believe were sub-standard that failed and caused this so hopefully no one else makes this same mistake..?
(Don't worry, I've lunched some parts before myself, including a brand new Crane cam!)
Old Aug 27, 2003 | 09:33 AM
Car: 87 T/A
The root cause of failure was a broken #6 exhaust outer valvespring. It actually broke a few days earlier, and had I been more diligent, I would possibly have discovered it. The car had begun to run a little rough, and I think the broken outer is why. Later, when winding it up, the inner was no match for inertia.
I had reused some 'green stripe' 1.550 valvesprings from Lunati (as mentioned before). They had been lying around a while, but I tested them out and set them up at like 170# on-seat. I think they were around 500# 0.500 at lift if I remember correctly. Height was 1.900. I used lash caps. I guess the solid roller cam probably didn't help, even though the lash was set correctly.
Anyways, bottom line, if you have to think twice about reusing a part, then don't do it.
I just pulled the engine/tranny combo out last night. I hope to find the cam and crank servicable. Then again, reuse is kinda sketchy now. You get gun-shy in a hurry.
Really, the worst thing right now is that my EFI test mule is down.
Old Aug 27, 2003 | 05:11 PM
Ken73's Avatar
Car: 82 Corvette
Yea, I'll be honest, too, I bought all new stuff; including a new cam and lifters; however, I didn't check that each lifter went in smooth. I started the motor up (for the first time) and YUM! That was a tasty cam. Lunched lifter and lobe for intake on #1. I was also using 1.6:1 roller tip rockers - I thought I had calculated everything out but when I went back over everything, I noticed that the lift with the springs (Crane, brand new to match the cam) was within .003" of the tolerance; I opted to not only go with 1.5:1 rockers, but go with a different cam entirely (the new cam has fairly similar tolerances, but has substantially less advertised duration, but more .050" duration.)
Talk about miserable; I lunched this cam within 30 minutes of starting the car!
So far the new cam seems to be working out great though, now I'm just down to tuning; everything else is set. Hopefully Bill will send me my prototype PROMinator quick so I can really tune faster.
ALIENhumanoid
Members Camaros
80
Apr 23, 2016 11:35 PM
greenyone
Sep 8, 2015 08:41 PM
Amillionoh7
Aug 7, 2015 01:24 PM
mult68
Aug 13, 2001 03:47 PM
I ROCK
Feb 26, 2001 10:30 PM
