disable egr in 8746
Old Sep 29, 2003 | 02:52 AM
TKD89RS's Avatar
Car: 1995
Engine: 5.7
disable egr in 8746
how do i disable the egr in a 91 rs with the 8746 chip. do i just change the on temp to 254 and disable it in the flags. also which flag is it.
Old Sep 29, 2003 | 07:16 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
You got it.
Old Sep 29, 2003 | 09:26 PM
TKD89RS's Avatar
Car: 1995
Engine: 5.7
would u happen to know which flag it is.
Old Sep 29, 2003 | 09:37 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
LD43B: FCB $B9 ; 1011 1001, 185
; b7 code 25, IAT Sensor Hi
; b6 code 31, MAP LOW, (NOT USED)
; b5 code 32, EGR failure,
; b4 code 33, MAP Sensor hi
; b3 code 34, MAP Sensor low
; b2 code 35, IAC error, (NOT USED)
; b1 code 41, NO DRP , (NOT USED)
; b0 code 42, EST Mon error
Old Sep 29, 2003 | 09:45 PM
TKD89RS's Avatar
Car: 1995
Engine: 5.7
thanks, ill take a look at that
Old Oct 16, 2003 | 12:47 AM
TKD89RS's Avatar
Car: 1995
Engine: 5.7
i dont see that grumpy. under flags i have six options to choose. Diagnostics @ 43A, 43B, and 43C. then i have options @0x0005, 0x0006, and 0x0007. there are numbered boxes under the diagnostics and the "B" boxes under options. do i just click off the "32" box under diagnostics?
TKD89RS's Avatar
Car: 1995
Engine: 5.7
and the 32 box is already not clicked. so whould clicking it disable
Old Oct 16, 2003 | 12:53 AM
TKD89RS's Avatar
Car: 1995
Engine: 5.7
i just tryed to change the on temp to 254 and it wont stay changed. anything above 150 and it changes it to a negative number. i type in 152 and it changes it to -40. is there another way to disable egr. maybe withthe tps, speed, or low map are my other options in it.
Old Oct 16, 2003 | 06:13 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
There are two EGR temperature locations (I don't have them with me). If using a hex editor set them to 0 (inverse temp term).
It sounds like you are using an editor and the conversion is off a little or such. It may be that 151° C is the max temperature. Set it to that and try it.
RBob.
Old Oct 17, 2003 | 08:33 AM
TKD89RS's Avatar
Car: 1995
Engine: 5.7
how would i know that worked. and do i click on the flag under diagnostics and click the 32 box. it is not clicked right now and in my stock chip it is not clicked. so im guessing clickign it disables it.
Old Oct 17, 2003 | 09:09 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Don't worry about the malfunction bit. Get a hex editor and goto $20C and then $20D in the bin and set them both to zero (0). Your EGR will then be disabled. Don't forget to redo the checksum before burning the chip.
RBob.
HoosierinWA
Oct 7, 2015 10:15 AM
jaridjohn
Oct 5, 2015 07:01 AM
djmarch
Oct 2, 2015 10:41 PM
meeklay812
Oct 1, 2015 03:46 PM
