Help a 100% Newb
Old Oct 16, 2003 | 04:32 AM
Daishi's Avatar
Car: 1988 Camaro IROC
Axle/Gears: 3.27 9 bolt posi (non 1le)
Help a 100% Newb
I know computers VERY well, and I LOVE cars, So why not combine the two..
However I have no intentions of programming my own chip, all I want is to be able to monitor my cars systems, and maybe play with some settings. Like someone before me mentioned the Fast and Furious, altho a dumb movie the laptop monitoring the manifold pressure was pretty nice. Anyone who can point me to a website that I can read about the misc software/hardware that is required to read sensors and such, would be great appreated.
Old Oct 16, 2003 | 08:00 AM
Jaysz28's Avatar
Car: 91 Firebird
Engine: 6.0
Try reading the sticky threads at the top of this forum
and Traxions tech article that is on this site
https://www.thirdgen.org/newdesign/tech/promintro.shtml
Old Oct 16, 2003 | 01:55 PM
Daishi's Avatar
I read that, and all I could find was programming info. Altho knowledge is nice, not quite what I'm looking for.
Anyone have info on.. lets say If I can hook a sensor up to my laptop so i can monitor engine temp for example??
Old Oct 16, 2003 | 02:09 PM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
what kind of induction do you have TPI? TBI? Carb?
for TPI, check out moates.net
for TBI check out. http://w1.601.telia.com/~u60113744/s...dl/winaldl.htm
Old Oct 16, 2003 | 02:29 PM
ski_dwn_it's Avatar
Engine: 2 mice and a cat
As far as software goes: Craig Moates served me well for a year or so.
After some computer problems, I got EASE. Its the best program I have ever used or seen. It NEVER fails to connect, always stays connected, runs in windows, and does about a MILLION thing to make graphing, comparing, etc all a snap.
But that is my opinion.
Old Oct 16, 2003 | 04:02 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
There are a bunch of sensors connected to the ECM. The easiest method to do what you want is to monitor these existing sensors via the ALDL line.
Search for scan software (Moates and WinALDL) along with just ALDL. This stuff runs on a laptop and has the ability to display the sensor information as read by the ECM.
RBob.
Old Oct 17, 2003 | 09:02 AM
kevinc's Avatar
Car: 1982 Z28
Just to warn you, when you get ALDL data acquisition going and see how far off spark and fueling are (most likely), you'll want to start burning your own chips.
<h5>
*this has been a public service announcement from Burn-aholics Anonymous*
Old Oct 17, 2003 | 12:38 PM
Daishi's Avatar
lol, I'll keep that in mind
Old Oct 17, 2003 | 01:01 PM
poncho@home's Avatar
Car: 2004 BMW 330Cic
Engine: 3.0
Transmission: 6 speed
Hi my name is Nektar and I am a BurnAholic.
Seriously though...I use Moates software and it works great. Just build or pickup an ALDL to Serial adapter and you'll have all the sensor information you can handle and then some....
After looking you might want to start touching!
Old Oct 17, 2003 | 11:48 PM
JP84Z430HP's Avatar
Car: 84 Z28
Engine: 355 (fastburn heads, LT4 HOT cam)
Axle/Gears: 9-bolt, 3.27
Unless you want to fix the shortfalls of the stock programming, why even look at the data from the sensors?
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
school boy
Oct 22, 2015 11:47 AM
bigjay89gta
Oct 15, 2015 08:04 AM
Royal_Z
Sep 30, 2015 08:45 PM
JSDaddy189
Sep 26, 2015 03:50 PM
