ZIF socket
Old Oct 21, 2003 | 08:13 AM
AstroRS's Avatar
ZIF socket
Is there anyway to attach a Zif socket to a 7747 ecm, to make changing chips a little easier?
Old Oct 21, 2003 | 08:34 AM
jwscab's Avatar
Engine: Many
Transmission: Quite a few
You can either plug a ZIF socket into the existing socket, and try and solder the pins in, or remove the socket altogether and replace with a ZIF. If you try that, the best thing to do is to try and clip out the socket (or pry out the plastic part)as much as possible BEFORE you try unsoldering the pins, since its hard to do all the pins at once without damaging the circuit board traces. Also, the board has a coating, which needs to burn off with the iron, or scraped off. Craig Moates has a great run-down with pictures on his site at www.moates.net, he goes one step further than just installing a ZIF socket, he offers upgrades to newer chips which are flash, they don't require a UV eraser to erase. Hope that helps.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Fronzizzle
Feb 9, 2017 09:31 AM
Fox118
Members Firebirds
111
Jan 26, 2016 07:17 PM
ramicio
Sep 28, 2015 01:18 PM
roysatikas
Sep 22, 2015 08:15 PM
