Can you forsure use a 730 as a 749??
Old Nov 2, 2003 | 02:31 PM
rooster433's Avatar
Bob aka Saturn 5 said it was possible..
has anyoen else tried it? I"m about to buy one
Old Nov 2, 2003 | 03:25 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: Can you forsure use a 730 as a 749??
Not aways. Depends upon usage. The '730 is short one injector driver over the '749. So if you wish to use 4 PnH's (port) then no. If you wish to use saturated injectors, then yes.
RBob.
Old Nov 2, 2003 | 03:40 PM
rooster433's Avatar
cant remeber.. saturated injectors are just your plain jane high impedence injector right?
Your saying as long as i don't run the low impedence i'll be fine
Old Nov 2, 2003 | 03:41 PM
SATURN5's Avatar
Car: 84 SVO
Engine: Volvo headed 2.3T
Transmission: WCT5
Axle/Gears: 8.8" 3.73
sat = high z
peak and holds = low z
TPI's are sat style, and a 730 will run those with $58 just fine.
BW
Old Nov 2, 2003 | 03:45 PM
rooster433's Avatar
sweet.. hate to question you.. i just wanted to make sure before i bought a 730 i would otherwize have no use for.
Now... do you think a 749 will run with a MSD tach signal? square 12v wave.
junkcltr
26
Jan 22, 2022 10:53 AM
F.I. 57 Belair
Aug 23, 2021 01:09 AM
Azrael91966669
25
Jun 20, 2017 04:04 AM
355tpipickup
Aug 19, 2015 10:02 PM
HighHopes85
Dec 3, 2001 06:28 PM
