power enrichment question?urgent
Old Nov 6, 2003 | 08:04 PM
88GTANOTCH's Avatar
ok , using tuner pro with the stock chip and an aftermarketchip(hypercrap) the graph(using tuner pro) shows it adding 1 degree of timing at 2000 rpm , 9.14 degrees at 3200 rpm , drops to just adding one more degree @ 4800 rpm.I can't understand why this happens at the same rpm in both chips?why such a spike? why so much timing at 3200 rpm? please help. it is the same on a 89 corvette and an 88 pontiac gta5.7. This make no sense to me ?
Old Nov 6, 2003 | 11:10 PM
Twilightoptics's Avatar
Car: '87 IROC-Z/'82 RX7
Engine: SBC 355/1.1L Rotary
Transmission: T56/5 Speed
Axle/Gears: 4.33/3.93
You're looking at the power enrichment spark adder tables. You have to take those tables, and add them ontop of your Main Spark table at the given load to determin your actual timing. Your main spark table may be high enough in the upper RPM range that no additional timing from the PE circuit is needed.
Though adding a few degrees on the high end of the PE spark helps.
I don't run any power enrichment spark. I have my main spark table do all the work.
MustangBeater20
Oct 29, 2022 09:20 PM
Vintageracer
Jan 10, 2020 05:33 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Bert87
Aug 23, 2015 03:50 PM
redmaroz
Aug 16, 2015 11:40 PM
