Cold starts and open loop driveability when cold
Old Nov 16, 2003 | 04:44 PM
3.8TransAM's Avatar
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
I already know that u have to have your main VE tables dialed in to near 128, or any other fueling correction will be off the intended target when in open loop. As far as that is concerned i am basically there and covered in that area.
November in the chicago area has lots of cold as u can imagine. Been experimenting with timing, fueling etc , for the cold starting and driveability issues i have been experiencing.
Cold starting has been pretty good for the most part. Only real issue i have their is the rpm flair upon startup where it leaps to 1500-2000rpm and then drops back to where it supposed to be. Starts withing first or second crank of the engine. As long as i can find out how to eliminate the flair there are no other issues.
Driveability when cold leave something to be desired.. Idle quality is not as smooth as closed loop control is and smoothness while accelerating is no where near as nice of a feeling as when closed loop. Have experimented in timing (adding) while cold and have noticed quite an improvement but not sure where to proceed from this point
3 biggest issues that i have now are:
1a) How else to eliminate the startup flair? (outside of dropping the park position steps)
1b) How to make the idle drop down correctly when open cold bfore the iac sets itself? (always hangs up when cold and slowly drops back to place when stopped)
2) Best way to determine timing during open loop cold start conditions? Any general rule of thumb or only trial and error?
3) Best way to determine fueling during open loop cold starts? Which tables are the most appropriate to adjust ? And any general rules of thumb or trial and error as the timing?
Thanks and later
Jeremy
PS trying to make it drive away nice and pretty no matter what the tempature is(lots of cold time in my area for me now)
Old Nov 16, 2003 | 06:07 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: Cold starts and open loop driveability when cold
Thanks and later
Jeremy
Hi, you are into the fun stuff now. A lot of this tuning is by the gut and the nose. Startup flair is by park position. The 'better' ECMs have a park steps vs temperature table. Work with this first. Then if the flair hangs too long, look for a kickdown delay table, or, even a temperature vs steps table (during run).
The smoothness during accel can be tough. Sometimes it takes going leaner, then richer to see what the engine requires.
A lot of times (sometimes?) it is the AE that is too rich. There should be an AE vs temperature table to change this.
I mention nose as that is how I did my idle AFR. When the O2 was happy and the BLM/INT was happy the exhaust was so bad the cats ran for cover. I leaned it out until the idle was still decent but the nose (and the cats!) were OK with it. How lean is it? Can't measure, too much cam. But it works. . .
RBob.
Old Nov 28, 2003 | 01:59 PM
3.8TransAM's Avatar
So far she seems to be liking slightly more timing than stock...........basically upped it 2 degrees where the stock cold timing table had + numbers and zeroed it out where it had larger - numbers.
Went back and took some fuel out as well anbd seemed to respond nicely... Also I did look inot the AE vs temp and trimmed it back some and found significant response in the pedal when i did.....
Will report further wheni have some time to play again
thanks guys
Jeremy
jklein337
Sep 19, 2018 06:23 PM
Wade787b
Sep 29, 2015 01:15 PM
Winchester1094
Aug 18, 2015 10:23 AM
mustangman65_79
Aug 8, 2015 12:07 PM
drathaar907
Aug 6, 2015 04:20 PM
