C.A.T.S. Engine Tuner question
Old Dec 10, 2003 | 05:12 PM
SLP_GTA's Avatar
In my quest to learn to burn I decided to download the program to get an idea what a BIN looks like.
I download some BINs and try to open with CATS and Im getting
"file indicates $8D ECM definition file should be used". I looked at the file I download and its configured $8D, what am I missing.
Old Dec 10, 2003 | 05:24 PM
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
You need the $8d TDF to view $8d .bin's
Did you copy the $8d tdf to the right folder?
If you did, you should be able to just open TC and select ECM_8d from ECM menu on tool bar, then open the .bin file.
Old Dec 10, 2003 | 05:33 PM
SLP_GTA's Avatar
that might be the problem 1badZ
the only option I have in TC is Files, Option, and Help. I downloaded the complete program, I thought it was a workable
program for the 30 day trail.
Old Dec 10, 2003 | 05:54 PM
Bill usn-1's Avatar
Car: IH Scout
Engine: 345 V8 TBI
Transmission: 727
AFAIK it only came with the $42 def.
Old Dec 10, 2003 | 08:48 PM
Guest
Guest
Posts: n/a
Thats correct. All the other tdf files are $20.
Old Dec 11, 2003 | 12:35 PM
scorp508's Avatar
Car: Corvettes
Engine: Modified L98 & LT5
Transmission: DN 4+3 & ZF6
Axle/Gears: 3.07 & 4.10
$42 is free and all others are $20.00 a pop. TC is seriously fast at getting things to you after ordrering from them or emailing them.
Old Dec 11, 2003 | 03:20 PM
SLP_GTA's Avatar
OK so what program with opens $8D
Also is there a definition screen with all of the different files? I have no clue what the other mean. $42, $20
I believe $8d are for 90-92 SD setup correct, please dont laugh
Old Dec 11, 2003 | 04:03 PM
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
$6E is for 1989 MAF TPI
$8D is for 90-92 Speed denisty TPI
84z96L31vortec
Aug 20, 2017 12:16 AM
Fast355
Dec 2, 2016 06:33 PM
redmaroz
Aug 16, 2015 11:40 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
djmarch
Aug 11, 2015 10:22 AM
