Trying to get my first chip to work
Old Dec 13, 2003 | 03:38 PM
Sp0nGa's Avatar
Car: 89 IROC
Engine: LB9
I have a the 165 ecu and Craig Moates adapter...
My stock chip is a 27C128 (16K x 8) and I am burning the exact same information on to a 27SF512 (64k x 8) chip. Using the 27SF512 chip, I switch the igintion key on and the fans start running. Also after the car has been started it idles really high and doesn't drop at all.
I swapped the stock chip into the adapter and it ran totally fine, so the adapter is working correctly. I remember reading something about when burning on bigger sized chips, the start and end device needs to be configured....?
I couldnt find any answers to my problems searching, Im stumped.
Any Suggestions will be greatly appreciated.
Jeff
Old Dec 13, 2003 | 07:04 PM
Kat's Avatar
Kat
Car: Camaro Vert
Engine: 355 HSR
Transmission: A4
Axle/Gears: 3.73 S60
In the programer software did you set the start of device to C000 hex ?
Kat
Old Dec 13, 2003 | 07:19 PM
Sp0nGa's Avatar
Car: 89 IROC
Engine: LB9
No i did not... I went through and changed it, now it works like a charm. Thank you
Old Dec 13, 2003 | 07:32 PM
Kat's Avatar
Kat
Car: Camaro Vert
Engine: 355 HSR
Transmission: A4
Anytime man!
Kat
Frozer!!!
Jan 19, 2024 04:55 PM
sailtexas186548
Exterior Parts for Sale
Feb 29, 2016 08:40 AM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
NBrehm
Aug 25, 2015 11:49 PM
NWAsonoma
Aug 18, 2015 05:45 PM
