VeMaster problem please help!
Old Jan 18, 2004 | 03:42 PM
Insomniac92z28's Avatar
Car: 92Z28
Transmission: A4
I am having trouble with vemaster. When I run it the file it changes cannot be opened by tunercat. It gives me the message "Selected source file is either corrupt or an unrecognizable format" I have yet to get it to work. I am running it on a datamaster "free" log file. Has anyone had this problem and how did you fix it?
Thanks,
Charlie
Old Jan 18, 2004 | 04:38 PM
Jaysz28's Avatar
Car: 91 Firebird
Engine: 6.0
You are trying to open the file that tells you the changes that VEMaster made.
When you select a bin to run VEMaster on, VEMaster saves those changes under the same bin name.
Example.
Datamaster file = test drive
Bin File = first try.bin
process Vemaster
new bin file = first try.bin
VEmaster file = first try changes.VEM (not sure of the file type and am too lazy to find my laptop and look)
so to save myself the aggravation you are going through, I make a copy of the bin and rename it before I run VEmaster.
Example:
first try.bin
first try1.bin
first try2.bin
etc
etc
for each time I run VEmaster on a bin I'm using. That way I can always go back if a chip doesn't burn or the laptop crashes, etc, etc, etc.
I also rename my bins for what I changed. If I am messing with my PE settings, I'll copy and rename my base bin to PE Changes.bin or something cheesy like that. Then I can always go back to the original, or back up one step if a change doesn't work right.
Good luck
Old Jan 18, 2004 | 04:46 PM
John Millican's Avatar
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
Rename your file from xxx.Bin to xxx.bin
Capitialization makes a differance.
Old Jan 18, 2004 | 05:04 PM
Car: 92Z28
Transmission: A4
No, I am trying to open the same TC file not the log file. I am not having any luck getting it to work. The file opens fine, I run VeMaster and it won't reopen and gives me the alert.
Thanks though,
Charlie
I can send someone the files if you would be willing to look at them.
Old Jan 19, 2004 | 07:09 AM
Jaysz28's Avatar
Car: 91 Firebird
Engine: 6.0
Well email me the before and after bin and I'll see what I can play with
turcottejay@hotmail.com
pjsparts
Oct 29, 2025 06:39 PM
88rscamar0
Sep 23, 2015 09:08 PM
Ranbo108
Sep 9, 2015 12:20 PM
383cam
Sep 9, 2015 06:01 AM
andy74
Sep 3, 2015 08:41 AM
