vss ecm changes
Old Jan 29, 2004 | 09:52 PM
gta_88_kicks's Avatar
Car: 1988 GTA
Engine: 355
Transmission: 700 r4
vss ecm changes
i was reading mike davis's swap info for 165 to 730 ecms, and i don't quite understand the vss changes needed. Especially when i read that 86 uses a different sensor than my 88. My understanding is that i have to hook the vss wire at A10 on the 165 ecm to the BC6 pin on the 730 ecm. Then in the 730 bin do i check or uncheck the vss flag?
another question: Which way do i look at sensors to figure out which pins are a,b, and c?
Old Jan 30, 2004 | 12:33 AM
PLANT PROTECTION's Avatar
Car: 1987 Monte Carlo SS
Transmission: 200-4R
Axle/Gears: 7.625 10 bolt/3.73s
From what I remember from my swap, the only change in the prom is unchecking the Magnetic VSS flag. I wouldn't look at the sensor to ID A, B, C, I associated the letters with wire color, it is all labled in Mike's ECM wiring pics. Good luck.
$750 L98
Feb 1, 2025 02:25 PM
InfernalVortex
Apr 20, 2021 11:31 AM
Falcon50
Aug 22, 2020 03:26 PM
TMZIrocZ350
Oct 7, 2015 12:09 PM
Jlanz55
Sep 29, 2015 08:55 AM
