wideband question....this is an odd one....
Old Jan 30, 2004 | 08:47 PM
11sORbust's Avatar
I have a 55,000 btu heater(i think). It accepts like 6 different type of fuels. I was wanting to se how clean each fuel burned. Maybe the wideband a/f meter would work?
Old Jan 30, 2004 | 11:03 PM
Z69's Avatar
Z69
Each fuel requires a different A/F ratio. So unless you know what each one requires. I know Nat Gas and Propane require different amounts of air. You have to change the "jets" out when switching a heater to get max efficiency I guess.
They make gas meters for checking furnace exhausts. Check Grainger's site.
Old Jan 31, 2004 | 12:33 AM
11sORbust's Avatar
there is no adjustments for different fuels. You just put em in and go. it takes diesel 1 or 2, fuel oil 1 or 2 ,jp8 ans a couple of others. I would bet one of em burn cleaner.
Old Feb 2, 2004 | 04:21 PM
Ronny's Avatar
i have been burnbing field corn grade 3 for years. i often wondered if the air dampner was adjusted correctly in my model 1010 high efficiency corn dogger. thank you innovate !! i will report next week on damper settings as soon as i get the pipes unfrozen to the house. -30 below here in hurley wis!
Old Feb 2, 2004 | 07:23 PM
Bill usn-1's Avatar
Car: IH Scout
Engine: 345 V8 TBI
Transmission: 727
From experience I can tell you the JP-8 runs hotter and cleaner than the kerosene in the space heaters like the alladin blue flame.
Old Feb 3, 2004 | 01:54 AM
11sORbust's Avatar
where to get JP-8???
Old Feb 3, 2004 | 07:04 AM
Dave_Jones's Avatar
Car: 83 TA, 89 TTA, others
Engine: ZZ4 TPI, LC2 turbo v6
Transmission: several, mostly broken
Hehehe...see your local recruiter.
Used to be, we ran the M1 tanks on JP-4 (jet fuel), and pretty much all the other ground equipment burned No.2 Diesel. Helicopters and I think most jet aircraft were also using JP-4. Back about 1996 or so, both fuels were replaced by JP-8. It's less volitile than JP-4, so there's less chance of explosion in a crash or from enemy fire. Also from the Army side, it was a lot easier on us to only have to supply one type of fuel for the ground forces.
I don't know if civilian aircraft are currently using JP-8 or not. It would make a lot of sense from the standpoint of crash survivability. I suspect you could make a phone call to the fuel point at your local airport and find out.
When we first started running Diesel engines on JP-8, we had all sorts of problems with injector pumps -- seems that the cleaner-running JP8 fuel was breaking loose all the crud that had accumulated over the years of running Diesel fuel. We rebuilt a bunch of injector pumps, and replaced about a zillion fuel filters during the first year or so, but eventually the problem worked itself out.
Anyway, that's your military fuel trivia for the day.
Old Feb 5, 2004 | 11:01 AM
11sORbust's Avatar
The heater has no adjustments for different types of fuel. That is why I want to test the effects of each type. I would imagine it would take only a few seconds to get a reading. So damage would seem unlikely. Would it work?
Old Feb 8, 2004 | 08:50 AM
11sORbust's Avatar
Is this a really dumb question or what??
Old Feb 10, 2004 | 12:08 PM
11sORbust's Avatar
I'm just going to try it. Don't know if it'll work but oh well...
Mark_ZZ3
May 24, 2018 01:02 PM
efiguy
Sep 27, 2015 01:30 PM
tuningnewb
Sep 23, 2015 07:06 PM
Stryker412
Sep 20, 2015 06:59 PM
Fronzizzle
Sep 8, 2015 12:10 PM
