Total spark timing
Old Feb 16, 2004 | 04:00 PM
ULTM8Z's Avatar
Total spark timing
Trying to dial in the spark timing (unfortunately without a dyno).
On a ZZ4, GM suggests running 10° BTDC at idle with the vacuum disconnected and 32° total at 4000 rpm with the vacuum disconnected. Would it be reasonable to put those two values into the table and try to work from there (i.e. 10° at 650 rpm and 100 kPa; 32° at 4000 rpm and 100 kpa)? Or is the EFI factor something that invalidates the ZZ4 spark advance R&D that GM did with the carb?
Thanks.
Old Feb 16, 2004 | 06:00 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
Re: Total spark timing
EFI just offers options that you can't do with carb/distributor setups.
~20 at idle
~30 cruise
WOT whatever works best for your combo.
You want to run the least consistant with max performance. Gotta be careful about running too much timing and too much fuel at WOT.
eightsixseven
Dec 16, 2024 01:50 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Red iroc-z 305
Sep 30, 2015 05:22 PM
Armored91Camaro
Aug 12, 2015 09:41 AM
