730 ECU file formatting
Car: American Iron Firebird
Engine: The little 305 that could.
Transmission: Richmond T-10
Axle/Gears: Floater 9" - 3.64 gears
Would anyone be interested in a 730 .ecu file that was formatted to be easier to read while in TunerPro? I keep missing items because it switches from all lowercase, to uppercase, to what I would call correctly formatted.
Ex.: VATS Enable (b4) instead of vats enable(b4)
I don't want to take the credit for the file by any means, but I'd like to clean it up. If there is interest, I could post it to Craig's file sharing site.
I'm also going to tackle adding tables for 3.8TransAm's Throttle Follower edits for those of us who don't use TunerCat and it's TDF definition files.
Sorry if this is newbie territory, but it's still new to me so I thought I'd throw the ideas out. Let me know what you think.
Well, it was very newbish evidently.
I re-read the thread and found that BOWTYE8 had already accomplished putting the Throttle Follower Stepping and Throttle Follower Gain into TunerPro.
Still, if anyone would still like to view the ECU file I will make it available.
Car: 69 Camaro
Engine: LS1 converted to LS6
Transmission: 4L70
Axle/Gears: 12bolt 3:42
I have already done what you are asking. I posted a thread called Project Super $8d to work with SAUJP along with having everything that was known about the ECU. I started with the basic and compared it to TC's definition. It should be on the Moates site shortly or you can email me.
KO1
16
Oct 15, 2015 05:00 PM
Linson
Oct 1, 2015 09:50 PM
