lt1 intake coolant port location
Old Feb 18, 2004 | 09:41 PM
junkcltr's Avatar
Engine: 3xx ci tubo
Transmission: 4L60E & 4L80E
I have searched the boards thoroughly looking for a definitive answer on the best place to tap the LT1 intake for coolant ports. I was looking for the best place in terms of cooling only, and don't care about the TB interference problems.
Grumpy says in a post that tapping off the rear of the intake is bad. Swapmaster says that it is better for cooling if tapped off the rear in another post. Both are smart guys. Who is correct? Neither posts why they say this.
Is there a thread that discusses this? Any help is appreciated.
J
Old Feb 18, 2004 | 09:47 PM
Mangus's Avatar
Car: '89 Trans Am WS6
Transmission: T5WC
Axle/Gears: 3.08 posi
if so, it certainly wouldn't be in the DIY PROM forum. :-D
Old Feb 18, 2004 | 10:23 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
Re: lt1 intake coolant port location
J
tap and Y the front two to the thermostat like the stock SBC setup.. if you want you can tap the pass side rear for the heater core like my cars stock setup... or you can T off of the front nipple line and run it that way.
read everything here:
www.lt1intake.com
Old Feb 18, 2004 | 10:34 PM
junkcltr's Avatar
Engine: 3xx ci tubo
I see what you are saying about running the coolant that way. John shows a picture that taps off of the front of the intake, but is now tapping off the rear. So the picture is out of date.
Lots of cooling cooling info at :
http://www.grapeaperacing.com/GrapeA...oolingmods.cfm
LT1Formula
20
Nov 14, 2015 12:02 AM
Dialed_In
Aug 20, 2015 01:45 PM
86White_T/A305
Aug 17, 2015 12:16 AM
Jake_92RS
Aug 11, 2015 10:39 AM
3rdgenparts
Exterior Parts for Sale
Aug 8, 2015 11:48 AM
