Help a newbie with idle A/F ratios
Old Feb 24, 2004 | 12:58 PM
ryan.h's Avatar
Well, here's the deal. I have a 3.4 DOHC engine (93 grand prix), and I need to adjust the fuel flow at "low pulse widths" i.e. I need to slightly enrich the occasions when the ECM is commanding a low pulse width... for instance, at idle, perhaps deceleration... I don't want the ECM overriding the 13.8 A/F ratio (or whatever it turns out to be) either by subtracting from the integrator or BL... I'm not knowledgeable in this stuff, but I'll pass the info along to a buddy that burns chips for me. Thanks for any help!!
Old Feb 25, 2004 | 11:30 AM
ryan.h's Avatar
Anyone? Gotta get this solved fairly quickly...
Old Feb 25, 2004 | 11:46 AM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
if you don't want it to use the BL corrections i would think you would have to disable closed loop, and run purely off the tables.
one of the smarter peopel here might know some trick to get the BL's to correct to a lower AFR, but that is beyond the scope of my knowledge.
Old Feb 25, 2004 | 02:05 PM
ryan.h's Avatar
I was afraid you were going to say that....
IROCtometal
Sep 20, 2015 11:08 PM
IROCtometal
Sep 9, 2015 10:01 AM
greenyone
Sep 8, 2015 08:41 PM
83 Crossfire TA
Sep 8, 2015 12:06 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
