Recommended Max timing in Main spark table
Old Feb 27, 2004 | 10:13 AM
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
What would you guys recommend for MAX timing in the main spark table for a 10 - 10.5 : 1 vortec headed TPI 350?
Just curious.
Right now I'm running 38* total. I've been told that's a couple degrees too high.
Old Feb 27, 2004 | 10:32 AM
11sORbust's Avatar
It's not too high IF there is no detonation. BUT you'll need to make timed runs to find the best total,while checking for detonation. I would start with 32* and time a 1/4mi run. Then go to 34*,36*,38*, taking notes of your mph and et for each degree setting(make sure to come off the line exaxtly same each time). Use the degree that nets the best et.I might reduce or increase timing in the upper rpms, if the engine likes it. Let me know what kind of timing you end up with.
You can see in the log data that I just make it flatline from 3X00rpms and up.
Old Feb 27, 2004 | 10:51 AM
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
How did you get the Air fuel ratio to show, do you have a DIY-Wide-band setup?
Old Feb 27, 2004 | 10:59 AM
11sORbust's Avatar
ignore that....it's just the calculated a/f ratio. I use a wideband o2. That version of datamaster is a beta(listed on thier site). I think trax said you can hook up the w/b to that beta version but i don't know how......
Old Feb 27, 2004 | 12:20 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
Re: Recommended Max timing in Main spark table
Sounds like you may have missed the tune.
If you run too rich, then you need too much timing. If your just racing then you can sort of use extra fuel to up the CR, but it's hard on things.
Might try taking some timing out, and then try leaning down a LITTLE bit at a time.
You have to accurately use a stop watch at this level to make sure you don't miss, best performance. The buttometer can be fooled.
Old Feb 28, 2004 | 09:15 AM
TRAXION's Avatar
Car: 2005 Subaru STI
Engine: 153ci of Turbo Power!
Transmission: 6-Speed
The WB has nothing to do with the scanning software that you use. The only 'hook up' is hooking the WB Vout to the correct pin on the ECM and running the hacked binary that pushes the REAL AFR to the AFR placeholder in the ALDL stream.
Tim
Old Feb 28, 2004 | 09:57 AM
11sORbust's Avatar
thanks
Old Feb 28, 2004 | 10:32 AM
OMINOUS_87's Avatar
Mike
Use the total timing spec given by GM for all their Vortec crate engines as a starting point, its the same for all of them?
38* is way to high to start at, why are you just picking random numbers anyway?
eightsixseven
Dec 16, 2024 01:50 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
gta90
Sep 15, 2015 04:00 PM
86White_T/A305
Aug 17, 2015 12:16 AM
Armored91Camaro
Aug 12, 2015 09:41 AM
