Good AFR's for power enrichment
Old Mar 4, 2004 | 11:14 PM
ULTM8Z's Avatar
I'm curious to know what you experienced guys would recommend for AFR's on my engine.
Here's an image from my spreadsheet. I built it so can input my table values from CATS and have it compute the resultant AFR. 92°C is close to my normal operating temperature. You can see my current value for %chg to AFR vs coolant in the upper left. The other table is %chg vs MAP. The table on the right is the resultant AFR.
Do these values look reasonable to you? The car runs pretty good right now, but without a dyno it's difficult to know if I'm on the money.
Old Mar 5, 2004 | 12:33 AM
PLANT PROTECTION's Avatar
Car: 1987 Monte Carlo SS
Transmission: 200-4R
Axle/Gears: 7.625 10 bolt/3.73s
Are you running 8d? That looks like an open loop table, not PE.
Old Mar 5, 2004 | 06:18 AM
TRAXION's Avatar
Car: 2005 Subaru STI
Engine: 153ci of Turbo Power!
Transmission: 6-Speed
I would very much recommend a Wide Band kit along with Mike Davis' modifications to allow you to view the true AFR in a scan program. It is absolutely invaluable. The calculated numbers are just that ... calculated. They mean nothing.
Tim
Old Mar 5, 2004 | 06:19 AM
TRAXION's Avatar
Agreed. That doesn't look like the power enrichment table ... or, did you mean startup enrichment???
Tim
Old Mar 5, 2004 | 08:22 AM
ULTM8Z's Avatar
Oops, sorry guys. Posted the wrong table. I had the open loop and power enrichment spreadsheets open at the same time and I must have grabbed the wrong one.
I'll have to repost the correct table tonight when I get home.
And yes it is an $8d.
Azrael91966669
25
Jun 20, 2017 04:04 AM
InfinityShade
Aug 22, 2015 08:00 PM
355tpipickup
Aug 13, 2015 07:35 AM
89mulletbird
Aug 12, 2015 07:08 PM
89mulletbird
Southern California Area
Aug 10, 2015 10:16 AM
