C3 ECM, 8192 possible?
Car: 82 Corvette
Engine: 350 CrossFire
Just curious of the experts' thoughts. Is it possible (albeit it would require a ROMless conversion most likely) to convert a C3 ECM to 8192 baud? For that matter, re-write things so it just sends the data *you* want it to..?
Car: check
Engine: check
Transmission: check
Re: C3 ECM, 8192 possible?
For something along the lines of a P4 ECM (8192 & 63 bytes of data) an add on card can also be done. No code changes required. It would be a basic or cut down Lockers system. Could also do something with added hardware and code changes that would be easier.
The C3 ECMs bit-bang the 160 baud data out via an I/O port. At a minimum would probably need a UART to serialize the data.
RBob.
Car: An Ol Buick
Engine: Vsick
Nothing approaches it.
The ROMless is an option, but then you wind up with one of a kind ecm. I won't plug the idea of doing source code for a P4
efiguy
Sep 27, 2015 01:30 PM
