7747 park neutral switch and TCC function?
I transplanted a 454 running with a 7747 into my Blazer with a 700r4. A 7747 is for a manuel tranny right? I was told this is why the park/neutral and TCC do not funtion(acording to scanner. Is this true?
Can i just pickup a chip for any TBI with an auto? Or does it have to be from a 454 with an auto? Thanks
Charlo
Charlo
Car: An Ol Buick
Engine: Vsick
Re: 7747 park neutral switch and TCC function?
The 7747 was used in both manual and auto applications.
Car: check
Engine: check
Transmission: check
Charlo
Charlo
As for the park/neut scanner info did you hook up the park/neut switch? May need to check it. I isn't too important in reality. Left open is same as a in-drive status.
The TCC is is dual purposed with the shift light. A auto bin wil control the TCC, a manual bin will control a shift light. They both use the same status bit internally.
RBob.
Hmm, the '747 will run either a manual or an auto tranny. Sounds like you have an auto, so best bet is to start with an auto bin.
The one I have is from a stick. I think that is why park/neutral does not work but i will double check my wiring.
Thanks guys
Charlo
Car: check
Engine: check
Transmission: check
So I need a bin from a 454 with 700r4? Not sure that was a combo from gm. Would a 454 with th400 work(no TCC)?
Thanks guys
Charlo
Thanks guys
Charlo
Start with a 454 auto bin and setup the TCC tables and go from there.
RBob.
454 auto trans bins are ACLU, ANTY, ATPX, AZFT.
AZFT was the latest revision, it is available here:
ftp://ftp.diy-efi.org/pub/gmecm/bin_...9/azft9503.bin
Ben.
Ben.
I'm dealing with this soon too, putting a 700R4 behind a 454. If you put in the TCC tables, will that make it re-purpose the signal to run the TCC instead of the kickdown? Or is there somewhere else in the code that needs to be tweaked?
Car: check
Engine: check
Transmission: check
RBob.
Street Lethal
Apr 30, 2019 12:14 PM
